I’d like to finally move completely to a new installation 100% on SSD. I already have a second openHAB running on a RPi2 with only root moved to SSD, which works flawlessly.
No I want my existing OH2 moved completely to the SSD. Is there something to be aware of? Or can I just clone my existing SD Card to the external SSD, connect that to one of the USB-ports of the RPI3?
Thanks! I’ll try this one!
Hi there,
I’m trying to migrate my Openhab2 setup from my SD card to a USB connected SSD drive.
I’ve followed the instructions linked to above:
pi@openhab ~ $ vcgencmd otp_dump | grep 17:
17:3020000a
I’ve then tried to clone the SD card to the SSD taking a copy of the image from the SD card and then writing it to the SSD drive.
I’d assumed that doing so would be the same as writing a default image, but there’s something I’m missing - I’ve tried modifying fstab and cmdline.txt on the SSD drive to no avail.
lsblk gives:
pi@openhab /boot $ lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
sda 8:0 0 111.8G 0 disk
├─sda2 8:2 0 14.8G 0 part
└─sda1 8:1 0 56M 0 part
mmcblk0 179:0 0 14.9G 0 disk
├─mmcblk0p2 179:2 0 14.8G 0 part /
└─mmcblk0p1 179:1 0 56M 0 part /boot
Cheers
James
