I have just installed OpenHabian on my RPi3 with a Razberry zwave board on it. But I am having issues getting the USB port show up and work as it should.
I am aware that for it to work, I have to disable Bluetooth - and I have had it running using other setups (Domoticz and Home Assistant). I am also aware that OpenHASbian should make the setup easier, by way of the Serial entry in openhasbian-config.
However, when I check the entries there ( and I check all three ), leave the config, and then go back, it is as if it does not remember my selection.
I then thought, its because I havent run the recomended ‘rpi-update’. So I did that, and now my Pi is unable to boot. I first thought something else went wrong, so I completely reinstalled, but the same thing happend.
Is the rpi-update nessesary for things to work - as far as I recall, running rpi-update on my other installs with Domoticz and Home Assistant, it went smoothly. But I dont know if this is openhasbian og rpi-update related.
Anyone able to help shed some light to all this, and hopefully get my OpenHab zwave up and running.
