Hi!
With a fresh openhabian (64bit) installed on my RPI4 4GB, I can’t make audio working with openhab.
It looks like sounds can be heard only when played via openhabian user and I can’t force openhab to make sounds hearable.
Everything seems to work ok as below, but I hear sound only when playing through openhabian user. When trying to play sound through openhab, root or some other newly created user I can’t hear anything. Does anybody have a clue how to fix it?
[10:17:10] root@openhabian:/usr/share/openhab/addons# groups openhabian
openhabian : openhab adm tty dialout cdrom sudo audio video plugdev games users input render bluetooth netdev spi i2c gpio openhabian
[10:20:38] root@openhabian:/usr/share/openhab/addons# sudo -u openhabian speaker-test -t wav -c 2
speaker-test 1.2.8
Playback device is default
Stream parameters are 48000Hz, S16_LE, 2 channels
WAV file(s)
Rate set to 48000Hz (requested 48000Hz)
Buffer size range from 480 to 32768
Period size range from 480 to 32768
Using max buffer size 32768
Periods = 4
was set period_size = 8192
was set buffer_size = 32768
0 - Front Left
1 - Front Right
Time per period = 2.404455
0 - Front Left
1 - Front Right
Time per period = 3.070715
0 - Front Left
1 - Front Right
[10:21:03] root@openhabian:/usr/share/openhab/addons# groups openhab
openhab : openhab tty dialout audio bluetooth gpio
[10:21:22] root@openhabian:/usr/share/openhab/addons# sudo -u openhab speaker-test -t wav -c 2
speaker-test 1.2.8
WAV file(s)
Periods = 4
0 - Front Left
1 - Front Right
Time per period = 2.407208
0 - Front Left
1 - Front Right
Time per period = 3.081668
0 - Front Left
1 - Front Right
