im moving from a 1.8 install to run on the latest openhabian version and all is good except for persistence!
in my rrd4j.persist file i have:
// persistence strategies have a name and a definition and are referred to in the “Items” section
Strategies {
// for rrd charts, we need a cron strategy
everyMinute : “0 * * * * ?”
Items {
Chart_Weather* : strategy = everyMinute, restoreOnStartup
Temperature : strategy = everyMinute, restoreOnStartup
the ‘Temperature’ item is working fine and logging every minute (checked the debug log and file timestamp)
the issue is the groups - the just aren’t logging. nothing is displayed in the debug.
i’ve tried with and without the asterisk no difference.
this works fine in 1.8 - i can’t find anything telling me oh2 is different.
can anyone please help? thanks!
hr3
(Harry)
August 1, 2017, 11:49am
2
Please can you show the definition of item und group for Chart_Weather.
If you copied it from demo.items the name is Weather_Chart.
to try to troubleshoot i only added one item to the group:
Group Chart_Weather
Number Temperature “Temperature [%.2f °C]” (Chart_Weather) {weather=“locationId=home, type=temperature, property=current”}
hr3
(Harry)
August 1, 2017, 12:15pm
4
This will save the item Temperatue 2 times.
What happens if you use only
thats the problem - its not!
its not logging for the group
i added the item ‘Temperature’ just to prove that it does actually work - i get this in the debug logs as expected:
14:07:00.018 [DEBUG] [sistence.rrd4j.internal.RRD4jService] - Stored ‘Temperature’ with state ‘21.00’ in rrd4j database
if i just have the group ‘Chart_Weather’ in the rrd4j.persist file then nothing gets written to the debug log and the database file does not get updated.
i get the exact same issue with mapdb - maybe this is a bug with this version of oh2?
Groups which shall be persisted have to be set to an item Type, so please define the Group as
Group:Number Chart_Weather
ok i tried changing the item file to:
but still the same - nothing getting logged.
has the format on this changed between oh1 and oh2? i’ve not found any documentation to say about the change?
i read more on the group types - but i don’t understand how this is needed for persistance. for example what i was doing with mapdb was to create a standard group containing all my plug sockets and persist that. i wasn’t trying to do an OR,MAX,MIN functions etc on them.
hr3
(Harry)
August 1, 2017, 5:10pm
8
My example works (2.2.0-SNAPSHOT Build #988 )
Group Chart_Weather
//Number Temperature "Temperature [%.2f °C]" (Chart_Weather) {weather="locationId=home, type=temperature, property=current"}
Number Temperature1 "Outside Temperature [%.1f °C]" <temperature> (Chart_Weather) { channel="yahooweather:weather:berlin:temperature" }
Number Sun_Elevation1 "Sun Elevation" <sun> (Chart_Weather) { channel = "astro:sun:home:position#elevation" }Contact c1
Contact c2
Contact c3
Strategies {everyMinute : "0 * * * * ?"}
Items {
Chart_Weather*, Temperature1, c1 : strategy = everyMinute, restoreOnStartup
Chart_Weather* , c2 : strategy = everyMinute, restoreOnStartup
Temperature1, c3 : strategy = everyMinute, restoreOnStartup
only Chart_Weather*, Temperature1, c1 : strategy = everyMinute, restoreOnStartup
2017-08-01 18:59:00.022 [DEBUG] [sistence.rrd4j.internal.RRD4jService] - Stored 'Sun_Elevation1' with state '19.14' in rrd4j database
2017-08-01 18:59:00.054 [DEBUG] [sistence.rrd4j.internal.RRD4jService] - Stored 'Temperature1' with state '30' in rrd4j database
2017-08-01 18:59:00.069 [DEBUG] [sistence.rrd4j.internal.RRD4jService] - Stored 'c1' with state 'CLOSED' in rrd4j database (again)
2017-08-01 18:59:00.069 [DEBUG] [sistence.rrd4j.internal.RRD4jService] - Stored 'c1' with state '0' in rrd4j database
only Chart_Weather*, c2 : strategy = everyMinute, restoreOnStartup
2017-08-01 18:55:00.006 [DEBUG] [sistence.rrd4j.internal.RRD4jService] - Stored 'Sun_Elevation1' with state '19.75' in rrd4j database
2017-08-01 18:55:00.022 [DEBUG] [sistence.rrd4j.internal.RRD4jService] - Stored 'Temperature1' with state '30' in rrd4j database
2017-08-01 18:55:00.053 [DEBUG] [sistence.rrd4j.internal.RRD4jService] - Stored 'c2' with state 'CLOSED' in rrd4j database (again)
2017-08-01 18:55:00.053 [DEBUG] [sistence.rrd4j.internal.RRD4jService] - Stored 'c2' with state '0' in rrd4j database
only Temperature1, c3 : strategy = everyMinute, restoreOnStartup
2017-08-01 19:00:00.116 [DEBUG] [sistence.rrd4j.internal.RRD4jService] - Stored 'Temperature1' with state '30' in rrd4j database
2017-08-01 19:00:00.272 [DEBUG] [sistence.rrd4j.internal.RRD4jService] - Stored 'c3' with state 'CLOSED' in rrd4j database (again)
2017-08-01 19:00:00.272 [DEBUG] [sistence.rrd4j.internal.RRD4jService] - Stored 'c3' with state '0' in rrd4j database
all Instructions
2017-08-01 18:53:00.022 [DEBUG] [sistence.rrd4j.internal.RRD4jService] - Stored 'Sun_Elevation1' with state '20.05' in rrd4j database
2017-08-01 18:53:00.053 [DEBUG] [sistence.rrd4j.internal.RRD4jService] - Stored 'Temperature1' with state '30' in rrd4j database
2017-08-01 18:53:00.068 [DEBUG] [sistence.rrd4j.internal.RRD4jService] - Stored 'c1' with state 'CLOSED' in rrd4j database (again)
2017-08-01 18:53:00.084 [DEBUG] [sistence.rrd4j.internal.RRD4jService] - Stored 'c1' with state '0' in rrd4j database
2017-08-01 18:53:00.115 [DEBUG] [sistence.rrd4j.internal.RRD4jService] - Stored 'c2' with state 'CLOSED' in rrd4j database (again)
2017-08-01 18:53:00.115 [DEBUG] [sistence.rrd4j.internal.RRD4jService] - Stored 'c2' with state '0' in rrd4j database
2017-08-01 18:53:00.162 [DEBUG] [sistence.rrd4j.internal.RRD4jService] - Stored 'c3' with state 'CLOSED' in rrd4j database (again)
2017-08-01 18:53:00.162 [DEBUG] [sistence.rrd4j.internal.RRD4jService] - Stored 'c3' with state '0' in rrd4j database
2017-08-01 18:53:01.131 [DEBUG] [sistence.rrd4j.internal.RRD4jService] - Stored 'Sun_Elevation1' with state '20.05' in rrd4j database
2017-08-01 18:53:01.178 [DEBUG] [sistence.rrd4j.internal.RRD4jService] - Stored 'Temperature1' with state '30' in rrd4j database
Check your quotation marks and change it from
to
Do you not use the SmartHome-Designer?
hr3
(Harry)
August 1, 2017, 7:21pm
9
I get this result with you example without any changes
2017-08-01 21:17:28.678 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model 'rrd4j.persist' has errors, therefore ignoring it: [5,19]: mismatched input 'â' expecting RULE_STRING
after changing the quotation marks it works
2017-08-01 21:22:27.334 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'rrd4j.persist'
2017-08-01 21:22:27.366 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'rrd4j.persist'
2017-08-01 21:23:00.022 [DEBUG] [sistence.rrd4j.internal.RRD4jService] - Stored 'Temperature' with state '19' in rrd4j database (again)
2017-08-01 21:23:00.022 [DEBUG] [sistence.rrd4j.internal.RRD4jService] - Stored 'Temperature' with state '20.6' in rrd4j database
2017-08-01 21:24:00.022 [DEBUG] [sistence.rrd4j.internal.RRD4jService] - Stored 'Temperature' with state '20.60000000000000142108547152020037174224853515625' in rrd4j database (again)
2017-08-01 21:24:00.022 [DEBUG] [sistence.rrd4j.internal.RRD4jService] - Stored 'Temperature' with state '20.6' in rrd4j database
