I have been searching everywhere, but can’t find out if there is a way to set the highest and lowest value you want displayed on a chart. For example, I want to have a chart displaying a temperature, but on days where the temperature stays mostly the same, I would rather if the chart didn’t auto range so even small temperature changes look really big.
Basically, I would like the chart to always have 0 degrees at the bottom and 40 degrees at the top, regardless of the data it has to work with.
Any ideas?
Regards,
Michel
