I’m using RRD4J for “drawing” the temperature of my sensors in a graph.
First, everything works fine (without errors) and the graph is now also working, but the console is spamming errors.
2018-05-16 18:42:24.702 [vent.ItemStateChangedEvent] - temperature changed from 23.50 to 23.56
2018-05-16 18:45:42.341 [vent.ItemStateChangedEvent] - temperature changed from 23.56 to 23.62
2018-05-16 18:48:00.542 [vent.ItemStateChangedEvent] - temperature changed from 23.62 to 23.69
2018-05-16 18:48:02.320 [WARN ] [eclipse.jetty.servlet.ServletHandler] - /chart
javax.imageio.IIOException: I/O error writing PNG file!
at com.sun.imageio.plugins.png.PNGImageWriter.write(PNGImageWriter.java:1168) [?:?]
at javax.imageio.ImageWriter.write(ImageWriter.java:615) [?:?]
at javax.imageio.ImageIO.doWrite(ImageIO.java:1612) [?:?]
at javax.imageio.ImageIO.write(ImageIO.java:1492) [?:?]
at org.eclipse.smarthome.ui.internal.chart.ChartServlet.doGet(ChartServlet.java:302) [155:org.eclipse.smarthome.ui:0.10.0.b1]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:687) [31:javax.servlet-api:3.1.0]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790) [31:javax.servlet-api:3.1.0]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:848) [88:org.eclipse.jetty.servlet:9.3.22.v20171030]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:584) [88:org.eclipse.jetty.servlet:9.3.22.v20171030]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) [191:org.ops4j.pax.web.pax-web-jetty:6.0.7]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548) [85:org.eclipse.jetty.security:9.3.22.v20171030]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:226) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1180) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:284) [191:org.ops4j.pax.web.pax-web-jetty:6.0.7]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:512) [88:org.eclipse.jetty.servlet:9.3.22.v20171030]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1112) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) [191:org.ops4j.pax.web.pax-web-jetty:6.0.7]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:134) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.server.Server.handle(Server.java:534) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:333) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:251) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:283) [79:org.eclipse.jetty.io:9.3.22.v20171030]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:108) [79:org.eclipse.jetty.io:9.3.22.v20171030]
at org.eclipse.jetty.io.SelectChannelEndPoint$2.run(SelectChannelEndPoint.java:93) [79:org.eclipse.jetty.io:9.3.22.v20171030]
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.executeProduceConsume(ExecuteProduceConsume.java:303) [90:org.eclipse.jetty.util:9.3.22.v20171030]
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.produceConsume(ExecuteProduceConsume.java:148) [90:org.eclipse.jetty.util:9.3.22.v20171030]
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.run(ExecuteProduceConsume.java:136) [90:org.eclipse.jetty.util:9.3.22.v20171030]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:671) [90:org.eclipse.jetty.util:9.3.22.v20171030]
at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:589) [90:org.eclipse.jetty.util:9.3.22.v20171030]
Caused by: org.eclipse.jetty.io.EofException
at org.eclipse.jetty.io.ChannelEndPoint.flush(ChannelEndPoint.java:199) ~[79:org.eclipse.jetty.io:9.3.22.v20171030]
at org.eclipse.jetty.io.WriteFlusher.flush(WriteFlusher.java:420) ~[79:org.eclipse.jetty.io:9.3.22.v20171030]
at org.eclipse.jetty.io.WriteFlusher.write(WriteFlusher.java:313) ~[79:org.eclipse.jetty.io:9.3.22.v20171030]
at org.eclipse.jetty.io.AbstractEndPoint.write(AbstractEndPoint.java:147) ~[79:org.eclipse.jetty.io:9.3.22.v20171030]
at org.eclipse.jetty.server.HttpConnection$SendCallback.process(HttpConnection.java:739) ~[87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.util.IteratingCallback.processing(IteratingCallback.java:241) ~[90:org.eclipse.jetty.util:9.3.22.v20171030]
at org.eclipse.jetty.util.IteratingCallback.iterate(IteratingCallback.java:224) ~[90:org.eclipse.jetty.util:9.3.22.v20171030]
at org.eclipse.jetty.server.HttpConnection.send(HttpConnection.java:519) ~[87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.server.HttpChannel.sendResponse(HttpChannel.java:750) ~[87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.server.HttpChannel.write(HttpChannel.java:801) ~[87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.server.HttpOutput.write(HttpOutput.java:235) ~[87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.server.HttpOutput.write(HttpOutput.java:219) ~[87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.server.HttpOutput.flush(HttpOutput.java:355) ~[87:org.eclipse.jetty.server:9.3.22.v20171030]
at javax.imageio.stream.FileCacheImageOutputStream.flushBefore(FileCacheImageOutputStream.java:258) ~[?:?]
at com.sun.imageio.plugins.png.IDATOutputStream.finishChunk(PNGImageWriter.java:196) ~[?:?]
at com.sun.imageio.plugins.png.IDATOutputStream.finish(PNGImageWriter.java:254) ~[?:?]
at com.sun.imageio.plugins.png.PNGImageWriter.write_IDAT(PNGImageWriter.java:945) ~[?:?]
at com.sun.imageio.plugins.png.PNGImageWriter.write(PNGImageWriter.java:1158) ~[?:?]
... 32 more
Caused by: java.io.IOException: Broken pipe
at sun.nio.ch.FileDispatcherImpl.write0(Native Method) ~[?:?]
at sun.nio.ch.SocketDispatcher.write(SocketDispatcher.java:47) ~[?:?]
at sun.nio.ch.IOUtil.writeFromNativeBuffer(IOUtil.java:93) ~[?:?]
at sun.nio.ch.IOUtil.write(IOUtil.java:51) ~[?:?]
at sun.nio.ch.SocketChannelImpl.write(SocketChannelImpl.java:471) ~[?:?]
at org.eclipse.jetty.io.ChannelEndPoint.flush(ChannelEndPoint.java:177) ~[79:org.eclipse.jetty.io:9.3.22.v20171030]
... 32 more
2018-05-16 18:48:02.681 [WARN ] [org.eclipse.jetty.server.HttpChannel] - //192.168.70.139:8080/chart?items=temperature&period=h&theme=bright&t=1526489282228
javax.servlet.ServletException: javax.imageio.IIOException: I/O error writing PNG file!
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:88) [191:org.ops4j.pax.web.pax-web-jetty:6.0.7]
Caused by: javax.imageio.IIOException: I/O error writing PNG file!
at com.sun.imageio.plugins.png.PNGImageWriter.write(PNGImageWriter.java:1168) ~[?:?]
at javax.imageio.ImageWriter.write(ImageWriter.java:615) ~[?:?]
at javax.imageio.ImageIO.doWrite(ImageIO.java:1612) ~[?:?]
at javax.imageio.ImageIO.write(ImageIO.java:1492) ~[?:?]
at org.eclipse.smarthome.ui.internal.chart.ChartServlet.doGet(ChartServlet.java:302) ~[?:?]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:687) ~[?:?]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790) ~[?:?]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:848) ~[?:?]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:584) ~[?:?]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) ~[?:?]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) ~[?:?]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548) ~[?:?]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:226) ~[?:?]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1180) ~[?:?]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:284) ~[?:?]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:512) ~[?:?]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185) ~[?:?]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1112) ~[?:?]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) ~[?:?]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) ~[?:?]
... 13 more
at org.eclipse.jetty.io.ChannelEndPoint.flush(ChannelEndPoint.java:199) ~[?:?]
at org.eclipse.jetty.io.WriteFlusher.flush(WriteFlusher.java:420) ~[?:?]
at org.eclipse.jetty.io.WriteFlusher.write(WriteFlusher.java:313) ~[?:?]
at org.eclipse.jetty.io.AbstractEndPoint.write(AbstractEndPoint.java:147) ~[?:?]
at org.eclipse.jetty.server.HttpConnection$SendCallback.process(HttpConnection.java:739) ~[?:?]
at org.eclipse.jetty.util.IteratingCallback.processing(IteratingCallback.java:241) ~[?:?]
at org.eclipse.jetty.util.IteratingCallback.iterate(IteratingCallback.java:224) ~[?:?]
at org.eclipse.jetty.server.HttpConnection.send(HttpConnection.java:519) ~[?:?]
at org.eclipse.jetty.server.HttpChannel.sendResponse(HttpChannel.java:750) ~[?:?]
at org.eclipse.jetty.server.HttpChannel.write(HttpChannel.java:801) ~[?:?]
at org.eclipse.jetty.server.HttpOutput.write(HttpOutput.java:235) ~[?:?]
at org.eclipse.jetty.server.HttpOutput.write(HttpOutput.java:219) ~[?:?]
at org.eclipse.jetty.server.HttpOutput.flush(HttpOutput.java:355) ~[?:?]
... 13 more
at org.eclipse.jetty.io.ChannelEndPoint.flush(ChannelEndPoint.java:177) ~[?:?]
... 13 more
