Remove rrd4j service from PaperUI
Stop OH
delete the rrd4j.persist
delete the rrd4j.cfg
Start OH
install rrd4j in paperUI
DO NOT modify rrd4j.cfg. The defaults are good enough without playing with them
and set-up rrd4j.persist as follow:
// persistence strategies have a name and a definition and are referred to in the "Items" section
Strategies {
everyMinute : "0 * * * * ?"
everyHour : "0 0 * * * ?"
everyDay : "0 0 0 * * ?"
default = everyChange
Items {
Bath_Humi, Bath_Temp : strategy = everyMinute, everyChange
2018-07-11 14:38:36.449 [vent.ItemStateChangedEvent] - Bath_Temp changed from 29.296875 to 28.296875
2018-07-11 14:38:39.971 [thome.event.ItemStateEvent] - Bath_Temp updated to 28.296875
2018-07-11 14:38:51.608 [ome.event.ItemCommandEvent] - Received event of type ‘ItemCommandEvent’ under the topic ‘smarthome/items/Bath_Temp/command’ with payload: ‘{“type”:“Decimal”,“value”:“29.296875”}’
2018-07-11 14:38:51.648 [ome.event.ItemCommandEvent] - Item ‘Bath_Temp’ received command 29.296875
2018-07-11 14:38:51.685 [thome.event.ItemStateEvent] - Bath_Temp updated to 29.296875
2018-07-11 14:38:51.692 [vent.ItemStateChangedEvent] - Received event of type ‘ItemStateChangedEvent’ under the topic ‘smarthome/items/Bath_Temp/statechanged’ with payload: ‘{“type”:“Decimal”,“value”:“29.296875”,“oldType”:“Decimal”,“oldValue”:“28.296875”}’
2018-07-11 14:38:51.706 [vent.ItemStateChangedEvent] - Bath_Temp changed from 28.296875 to 29.296875
2018-07-11 14:38:57.710 [thome.event.ItemStateEvent] - Bath_Temp updated to 28.296875
2018-07-11 14:38:57.775 [vent.ItemStateChangedEvent] - Received event of type ‘ItemStateChangedEvent’ under the topic ‘smarthome/items/Bath_Temp/statechanged’ with payload: ‘{“type”:“Decimal”,“value”:“28.296875”,“oldType”:“Decimal”,“oldValue”:“29.296875”}’
2018-07-11 14:38:57.783 [vent.ItemStateChangedEvent] - Bath_Temp changed from 29.296875 to 28.296875
2018-07-11 15:31:33.768 [WARN ] [nce.extensions.PersistenceExtensions] - There is no queryable persistence service registered with the id ‘rrd4j’
2018-07-11 15:31:34.101 [WARN ] [nce.extensions.PersistenceExtensions] - There is no queryable persistence service registered with the id ‘rrd4j’
2018-07-11 15:31:34.489 [WARN ] [nce.extensions.PersistenceExtensions] - There is no queryable persistence service registered with the id ‘rrd4j’
2018-07-11 15:31:34.823 [WARN ] [nce.extensions.PersistenceExtensions] - There is no queryable persistence service registered with the id ‘rrd4j’
2018-07-11 15:31:35.021 [WARN ] [nce.extensions.PersistenceExtensions] - There is no queryable persistence service registered with the id ‘rrd4j’
2018-07-11 15:31:35.229 [WARN ] [nce.extensions.PersistenceExtensions] - There is no queryable persistence service registered with the id ‘rrd4j’
2018-07-11 15:31:35.427 [WARN ] [nce.extensions.PersistenceExtensions] - There is no queryable persistence service registered with the id ‘rrd4j’
Yes, i remove from paperUI rrd4j persistence, stop OH and remove rrd4j.cfg and rrd4j.persist. Start OH and reinstall rrd4j. And put new file rrd4.persist.
