I’ve recently migrated over to openHAB 4 from openHAB 3, to keep it all clean I did a fresh install and copied over the essential things I needed.
Now, I’ve noticed that RRD4j is not recording any changes at all, I have made no changes to this (I believe this is the default persistence service). I also have MapDB installed which is specifically used to store string items for times of the day, which is configured in a .persist file.
@ubeaut I agree the Main UI may be easier and less prone to human errors, but for me its just a personal preference to have text based files. Also, MapDB that does have a .persist file works as expected.
@rlkoshak thanks for the information here. I have also installed RRD4j addon. Where do I set the default persistence service and once I do this do I need to set what I’d like to record or will it automatically start recording every change to every item?
Again thank you for the responses, really appreciate them
The two files you mention seem to be more of the config for rrd4j persistence. But where can I set the default persistence service for OH on a text based config?
################################# PERSISTENCE ##################################
# The persistence service to use if no other is specified.
#org.openhab.persistence:default=
