On openHAB2 i have a problem with restore on startup. It works on openHAB1. In openhab.log I see an errormessage at line 3 : unknown property name : org.openhab.persistence.rrd4j, while later Loading model ‘rrd4j.persist’ is succesful.
I cannot find the problem. Do you have a suggestion ?
Gert
Here the beginning of openhab.log:
2015-10-12 14:36:38.911 [INFO ] [u.h.internal.servlet.HABminApp] - Started HABmin servlet at /habmin
2015-10-12 14:36:42.016 [INFO ] [.b.r.internal.RFXComConnection] - Connecting to RFXCOM [serialPort=‘COM5’ ].
2015-10-12 14:36:42.234 [WARN ] [.p.rrd4j.internal.RRD4jService] - Unknown property name : org.openhab.persistence.rrd4j
2015-10-12 14:36:42.234 [INFO ] [.p.rrd4j.internal.RRD4jService] - Removing invalid defintion component = null heartbeat = 0 min/max = 0.0/0.0 step = 0 0 archives(s) = [] 0 items(s) = []
2015-10-12 14:36:44.268 [INFO ] [o.i.m.internal.MyOpenHABClient] - Connected to my.openHAB service (UUID = 2c004f42-8052-41b5-a575-62ebc5892b64, base URL = http://localhost:8080)
2015-10-12 14:36:44.378 [INFO ] [ui.internal.servlet.PaperUIApp] - Started Paper UI at /ui
2015-10-12 14:36:45.197 [INFO ] [.b.a.internal.bus.AstroBinding] - AstroConfig[latitude=51.813,longitude=5.7991,interval=disabled,systemTimezone=Europe/Berlin (CET +0200),daylightSavings=true]
2015-10-12 14:36:45.248 [INFO ] [.service.AbstractActiveService] - HTTP Refresh Service has been started
2015-10-12 14:36:45.348 [INFO ] [.u.d.internal.DashboardService] - Started dashboard at /start
2015-10-12 14:36:45.387 [INFO ] [.z.internal.ZWaveActiveBinding] - Update config, port = COM6
2015-10-12 14:36:45.388 [INFO ] [.z.internal.ZWaveActiveBinding] - Update config, masterController = true
2015-10-12 14:36:45.388 [INFO ] [.service.AbstractActiveService] - FrontierSiliconRadio Service has been started
2015-10-12 14:36:45.389 [INFO ] [.service.AbstractActiveService] - ZWave Refresh Service has been started
2015-10-12 14:36:45.401 [INFO ] [b.z.i.protocol.ZWaveController] - Starting Z-Wave controller
2015-10-12 14:36:45.402 [INFO ] [b.z.i.protocol.ZWaveController] - Z-Wave timeout is set to 5000ms. Soft reset is false.
2015-10-12 14:36:45.402 [INFO ] [b.z.i.protocol.ZWaveController] - Connecting to serial port COM6
2015-10-12 14:36:45.421 [INFO ] [b.z.i.protocol.ZWaveController] - Serial port is initialized
2015-10-12 14:36:45.733 [INFO ] [.s.u.c.i.servlet.WebAppServlet] - Started Classic UI at /classicui/app
2015-10-12 14:36:45.800 [INFO ] [.o.core.internal.CoreActivator] - openHAB runtime has been started (v2.0.0, build 201510070911).
2015-10-12 14:36:45.883 [INFO ] [.e.s.m.c.i.ModelRepositoryImpl] - Loading model ‘Gertshuis.sitemap’
2015-10-12 14:36:46.125 [INFO ] [.e.s.m.c.i.ModelRepositoryImpl] - Loading model ‘Gertshuis.things’
2015-10-12 14:36:46.297 [INFO ] [.e.s.m.c.i.ModelRepositoryImpl] - Loading model ‘myopenhab.persist’
2015-10-12 14:36:46.332 [INFO ] [.e.s.m.c.i.ModelRepositoryImpl] - Loading model ‘rrd4j.persist’
2015-10-12 14:36:46.392 [INFO ] [.e.s.m.c.i.ModelRepositoryImpl] - Loading model ‘Gertshuis.rules’
2015-10-12 14:36:46.859 [INFO ] [.e.s.m.c.i.ModelRepositoryImpl] - Loading model ‘Gertshuis.items’
