RRD4J Presinstence (on Synology with OpenHAB 1.8.1)
Dears,
I’m impressed how simple the configuration of OpenHAB looks like, but struggling with some Details :blush:
For rrd4j-persistence it seems to be that only «openhab.cfg», «default.sitemap» and «rrd4j.persist» are needed to be configured. (see my files {i.e. extracts of the files} below).
The rrd-file exists: «volume1/@appstore/OpenHAB/etc/rrd4j/strom_w.rrd» (rights rw-r–r-- / Owner: openhab)
But unfortunatley the chart does not contain data (i.e. no y-axis data).
What do i have to configure/check in order to display the Data in the Chart?
KR Urs
Synology DS1513+
DSM 6.0-7321 Update 3
OpenHab 1.8.1-001
// openhab.cfg (extract only)
folder:persistence=10,persist
persistence:default=rrd4j
//openhab.cfg END
// default.sitemap (extract only)
Chart item=Strom_W period=h refresh=10000
// default.sitemap END
// rrd4j.persist (whole file)
section
Strategies {
everyMinute : “0 * * * * ?”
everyHour : “0 0 * * * ?”
everyDay : “0 0 0 * * ?”
default = everyChange
Items {
Strom_W : strategy = restoreOnStartup, everyChange
// rrd4j.persist END
You have to use the everyMinute strategy.:
Strom_W : strategy = everyMinute, everyChange, restoreOnStartup
Hi Udo
Yes, it works with
I will do some tests to get the Point (i.e sequence wrong or everyChange can not be the only strategy…
Unfortunately Persistence · openhab/openhab1-addons Wiki · GitHub is not so detailed…
Thank you!
Urs
The reason is, building the chart needs 1 Datapoint per Minute, so everyMinute as strategy is mandatory, while everyChange will improve data accuracy, restoreOnStartup is only needed to reload the last known state to the item when restarting openHAB.
Thank you!
It worked. :relaxed:
