I’m trying to access persistence data via the REST API.
While http://IP:PORT/rest/items/ITEM/state' is working great, the following two persistence calls are both failing with a 404 error:
http://IP:PORT/rest/persistence/rrd4j/ITEMNAMEhttp://IP:PORT/rest/persistence/ITEMNAME?servicename=rrd4j
Further I assume that persistence is working properly, because OH2 is showing the concerned ITEM data in a chart and I checked the data with the RrdInspector.
Any ideas? Thanks
