Starting to use RRD Charts to visualize my data. When looking at the time scale set to hours, the charts use the 24 hour format. I don’t really see much documentation on these charts, but wondering if it is possible to configure the time scale to show 12 hour (am/pm) format?
I use rrd or mysql and I just need better graphs. Is there a tool for widows that can read the rrd files and generated bitmaps on regular intervals…or some web server (local) that will generate those dynamicly from MySQL on each web request.
The rrd4j database OH uses is a special Java version for which, if I remember correctly, rrd4 tools does not work. There are tons of graphing libraries in JavaScript out there that people use but you are looking to need to set up a separate web server to generate and expose these charts. InfluxDB has a ton of tools and libraries written around it and is probably the place I would look.
But I’m really not the right person to answer this. I’ve done zero research into this.
However, I do remember a thread while back with someone who wrote a binding that generates better charts. If you search the forum you hopefully can find it.
