So, now a sequel again:
I wanted to add another functionality
and created some groups and items for it.
Everything works except for the creation of the last items in the groups and I don’t understand why at all.
I have already deleted the new rrd files of the items and then restarted rrd4j. As long as I don’t include any of the last open items, everything works, but if I include even one of the last items, it crashes immediately.
This is the config of one (IFSR_HeatRequested - it commented out here) of the failing new items (6 in number):
Group:Number:SUM gIR_HeatRequests
Group:Number:COUNT("ON") gIBR_HeatRequests (gIR_HeatRequests)
Group:Number:COUNT("ON") gIGR_HeatRequests (gIR_HeatRequests)
Group:Number:COUNT("ON") gIFR_HeatRequests (gIR_HeatRequests)
Group IFS_Radiator "HK Schlafzimmer" <radiator> (IF_Schlafzimmer,OG_Radiators) ["RadiatorControl"]
Number IFSR_Current "Temperatur" <temperature> (IFS_Radiator,OG_RadiatorCurrents) ["Temperature"] { channel="zwave:device:z_wave_ctrl_01:node13:sensor_temperature" }
Number IFSR_Dest "Soll" <temperature> (IFS_Radiator,OG_RadiatorDestinations) ["Temperature"] { channel="zwave:device:z_wave_ctrl_01:node13:thermostat_setpoint_heating" }
Number IFSR_Mode_Internal "Thermostat-Modus" <radiator> (IFS_Radiator) ["Temperature"] { channel="zwave:device:z_wave_ctrl_01:node13:thermostat_mode" }
Number IFSR_Day "Soll (Tag)" <temperature_hot> (IFS_Radiator) ["Temperature"]
Number IFSR_Night "Soll (Nacht)" <temperature_cold> (IFS_Radiator) ["Temperature"]
String IFSR_Mode_Active "Modus (soll)" <radiator> (IFS_Radiator,OG_RadiatorModeActives)
String IFSR_Mode_Valve "Ventilmodus" <radiator> (IFS_Radiator,OG_RadiatorModeValves)
Number IFSR_Batterie "HK Schlafzimmer" <batterylevel> (IFS_Radiator,IH_BatteryLevels) ["Energy"] { channel="zwave:device:z_wave_ctrl_01:node13:battery-level" }
String IFSR_TLP_TransferItem "[%s]" (IFS_Radiator,gTimepicker)
Dimmer IFSR_ValveOpening "Ventilöffnung" (IFS_Radiator,OG_RadiatorValveOpenings) ["Opening"] { channel="zwave:device:z_wave_ctrl_01:node13:switch_dimmer"}
// Switch IFSR_HeatRequested "Wärmeanforderung" <heating> (IFS_Radiator,gIFR_HeatRequests) ["Energy"]
This is the log without the item IFSR_HeatRequested:
2022-09-17 12:44:01.309 [TRACE] [d4j.internal.RRD4jPersistenceService] - Ignoring item 'IFSR_Mode_Active' since its type String is not supported
2022-09-17 12:44:01.310 [DEBUG] [d4j.internal.RRD4jPersistenceService] - Stored 'IFSR_Day' as value '19.0' in rrd4j database (again)
2022-09-17 12:44:01.312 [DEBUG] [d4j.internal.RRD4jPersistenceService] - Stored 'IFSR_Night' as value '16.0' in rrd4j database (again)
2022-09-17 12:44:01.313 [DEBUG] [d4j.internal.RRD4jPersistenceService] - Stored 'IFSR_Current' as value '18.75' in rrd4j database (again)
2022-09-17 12:44:01.314 [DEBUG] [d4j.internal.RRD4jPersistenceService] - Stored 'IFSR_Current' as value '18.75' in rrd4j database
2022-09-17 12:44:01.315 [DEBUG] [d4j.internal.RRD4jPersistenceService] - Stored 'IFSR_Batterie' as value '50.0' in rrd4j database (again)
2022-09-17 12:44:01.316 [DEBUG] [d4j.internal.RRD4jPersistenceService] - Stored 'IFSR_Batterie' as value '50.0' in rrd4j database
2022-09-17 12:44:01.317 [TRACE] [d4j.internal.RRD4jPersistenceService] - Ignoring item 'IFSR_TLP_TransferItem' since its type String is not supported
2022-09-17 12:44:01.318 [DEBUG] [d4j.internal.RRD4jPersistenceService] - Stored 'IFSR_Dest' as value '16.0' in rrd4j database (again)
2022-09-17 12:44:01.320 [DEBUG] [d4j.internal.RRD4jPersistenceService] - Stored 'IFSR_ValveOpening' as value '0.0' in rrd4j database (again)
2022-09-17 12:44:01.321 [TRACE] [d4j.internal.RRD4jPersistenceService] - Ignoring item 'IFSR_Mode_Valve' since its type String is not supported
2022-09-17 12:44:01.322 [DEBUG] [d4j.internal.RRD4jPersistenceService] - Stored 'IFSR_Mode_Internal' as value '0.0' in rrd4j database (again)
when IFSR_HeatRequested is not commented out I get following logs:
2022-09-17 12:52:15.340 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'og_schlafzimmer.items'
2022-09-17 12:52:15.372 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'IFSR_HeatRequested' changed from NULL to OFF
2022-09-17 12:53:00.842 [WARN ] [ore.internal.scheduler.SchedulerImpl] - Scheduled job '<unknown>' failed and stopped
java.lang.IllegalArgumentException: Null consolidation function specified
at org.rrd4j.core.ArcDef.<init>(ArcDef.java:43) ~[?:?]
at org.rrd4j.core.RrdDb.getRrdDef(RrdDb.java:1288) ~[?:?]
at org.openhab.persistence.rrd4j.internal.RRD4jPersistenceService.getConsolidationFunction(RRD4jPersistenceService.java:397) ~[?:?]
at org.openhab.persistence.rrd4j.internal.RRD4jPersistenceService.store(RRD4jPersistenceService.java:142) ~[?:?]
at org.openhab.core.persistence.internal.PersistItemsJob.run(PersistItemsJob.java:60) ~[?:?]
at org.openhab.core.internal.scheduler.CronSchedulerImpl.lambda$0(CronSchedulerImpl.java:62) ~[?:?]
at org.openhab.core.internal.scheduler.CronSchedulerImpl.lambda$1(CronSchedulerImpl.java:69) ~[?:?]
at org.openhab.core.internal.scheduler.SchedulerImpl.lambda$12(SchedulerImpl.java:191) ~[?:?]
at org.openhab.core.internal.scheduler.SchedulerImpl.lambda$1(SchedulerImpl.java:88) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304) [?:?]
When I delete the rrd-file an restart the rrd4j I get following additional trace line to the error:
2022-09-17 13:06:01.062 [TRACE] [d4j.internal.RRD4jPersistenceService] - Using rrd definition 'default_other = GAUGE heartbeat = 3600 min/max = NaN/NaN step = 5 4 archives(s) = [ LAST xff = 0.5 steps = 1 rows = 720 LAST xff = 0.5 steps = 12 rows = 10080 LAST xff = 0.5 steps = 180 rows = 35040 LAST xff = 0.5 steps = 2880 rows = 21900] 0 items(s) = []' for item 'IFSR_HeatRequested'.
2022-09-17 13:06:01.256 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
java.lang.InternalError: a fault occurred in a recent unsafe memory access operation in compiled Java code
at jdk.internal.misc.Unsafe.putLongUnaligned(Unsafe.java:3553) ~[?:?]
at java.nio.ByteBufferAsDoubleBufferB.put(ByteBufferAsDoubleBufferB.java:145) ~[?:?]
at java.nio.DoubleBuffer.put(DoubleBuffer.java:887) ~[?:?]
at org.rrd4j.core.ByteBufferBackend.writeDouble(ByteBufferBackend.java:81) ~[?:?]
at org.rrd4j.core.RrdPrimitive.writeDouble(RrdPrimitive.java:78) ~[?:?]
at org.rrd4j.core.RrdDoubleMatrix.<init>(RrdDoubleMatrix.java:15) ~[?:?]
at org.rrd4j.core.Archive.<init>(Archive.java:66) ~[?:?]
at org.rrd4j.core.RrdDb.<init>(RrdDb.java:482) ~[?:?]
at org.rrd4j.core.RrdDb.of(RrdDb.java:417) ~[?:?]
at org.openhab.persistence.rrd4j.internal.RRD4jPersistenceService.getDB(RRD4jPersistenceService.java:331) ~[?:?]
at org.openhab.persistence.rrd4j.internal.RRD4jPersistenceService.store(RRD4jPersistenceService.java:140) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515) ~[?:?]
How can I solve this problem ?
PS: It is also interesting that I have already successfully integrated exactly these items on other radiators.
PPS: Ok, there is a small update:
For test reasons, I wanted to save all rrd files and then delete them (not only those of the items with the problem as I did before)
But that caused other problems (e. g. now I also know that the persistence files are in an overlay directory).
The result is that I lost all my historical data - but I was now able to create the last items without any problems.
If anyone has any tips on how I should have proceeded better in this case or what the cause probably was - please let me know.
