Hi Guys .
How would I do the communication to and from the unit. I can’t get much from the site.
is it worth using it or not ?
will be using it with my rpi 3B
You can use the Serial binding to communicate with this device. But you will have to find documentation for or reverse engineer the commands and data sent back and forth.
Thanks for the information.
I will see what I can find and then share it with the world ( OPENHAB World)
If you buy the same outdoor unit with the ip observer unit there is a binding that already works. That is a fine offset produced unit
I am not sure if it is available in South Africa.
these are the two that I am looking at ?
and
Not sure if they have the ip observer with
