I’m currently running openHAB 5.1.4 on a Raspi 5 with openhabian.
Yesterday I checked the logs of sdrsync.service and saw that there are issues with some files, e.g.:
Jun 10 18:09:48 openhabian mirror_SD[782884]: rsync: [generator] recv_generator: failed to stat "/storage/syncmount/usr/share/nodejs/caniuse-lite/data/regions/GG.js": Bad message (74)
They were all from the nodejs folder.
The only way to fix this was to run a raw sync by manually starting the sdrawcopy.service. Afterwards, the sdrsync.service ran without an issue.
I’m not sure if this is an issue with the backup SD card. It’s a SanDisk High Endurance and only used for the backup, i.e. there are not a lot of writes done.
Did anyone else observe something similar?
Would it be possible to show such issues more prominently, e.g. in openhabian-config and advise the user to try a raw sync or check the backup card?
