Issue of the topic:
Two days ago the last message was written to /var/log/events.log.
In /var/log/messages I found a lot of messages “syslogd: rsyslogd[internal_messages]: x messages lost due to rate-limiting”
df -h gives the following result:
/dev/zram1 130M 127M 0 100% /opt/zram/zram1
overlay1 130M 127M 0 100% /var/log
But in /etc/ztab I found
log alg mem_limit disk_size target_dir bind_dir oldlog_dir
log lzo-rle 150M 500M /var/log /log.bind
Normally there should be 20M space left
However I’ve found not really any explanation how to increase /dev/zram1.
Is increasing the right action to get logging back working?
What should I do?
Thank you for answering so fast.
Trying to answer your question in detail, I’ve just started “sudo openhabian-config”. It told me that I’m not on the actual repository. I switched. Afterwards I tried to update my system, but getting a lot of errors:
dpkg: could not open log ‘/var/log/dpkg.log’: No space left on device
Setting up mariadb-common (1:10.3.29-0+deb10u1) …
update-alternatives: error: cannot append to ‘/var/log/alternatives.log’: No space left on device
dpkg: error processing package mariadb-common (–configure):
installed mariadb-common package post-installation script subprocess returned error exit status 2
Errors were encountered while processing:
mariadb-common
Updating FireMotD available updates count …
N: Ignoring file ‘openhab.liste’ in directory ‘/etc/apt/sources.list.d/’ as it has an invalid filename extension
W: Target Packages (main/binary-armhf/Packages) is configured multiple times in /etc/apt/sources.list.d/openhab-linuxpkg.list:7 and /etc/apt/sources.list.d/openhab.list:1
W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/openhab-linuxpkg.list:7 and /etc/apt/sources.list.d/openhab.list:1
W: Target Translations (main/i18n/Translation-en_GB) is configured multiple times in /etc/apt/sources.list.d/openhab-linuxpkg.list:7 and /etc/apt/sources.list.d/openhab.list:1
W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/openhab-linuxpkg.list:7 and /etc/apt/sources.list.d/openhab.list:1
W: Target Translations (main/i18n/Translation-en_GB.UTF-8) is configured multiple times in /etc/apt/sources.list.d/openhab-linuxpkg.list:7 and /etc/apt/sources.list.d/openhab.list:1
W: Problem unlinking the file /var/log/apt/eipp.log.xz - FileFd::Open (28: No space left on device)
W: Could not open file /var/log/apt/eipp.log.xz - open (17: File exists)
W: Could not open file ‘/var/log/apt/eipp.log.xz’ - EIPP::OrderInstall (17: File exists)
W: Could not open file ‘/var/log/apt/term.log’ - OpenLog (28: No space left on device)
E: Sub-process /usr/bin/dpkg returned an error code (1)
FAILED
Yes I’m using openhabian. It says “3.0.2 - Release Build” at the login screen.
What would be a next good step to solve one of all the problems?
