Hello openHAB community!
I’m a beginner with openHAB and ran into a problem which seems like a bug but is probably something I’m doing wrong… :o)
I am trying to react on one door being opened (HM-Sec-SCo).
My rule is more complex, minimal example:
rule "Badtuer"
Item BD_Tuer_State changed
then {
logInfo ("FILE", "Bad: Türsensor ausgelöst: " + BD_Tuer_State.state)
if (BD_Tuer_State.state == OPEN) {
logInfo ("FILE", "Bad: Türsensor ausgelöst beim Öffnen.")
events.log
2016-02-07 19:19:48 - BD_Tuer_LowBat state updated to OFF
2016-02-07 19:19:48 - BD_Tuer_State state updated to true
2016-02-07 19:19:50 - BD_Tuer_LowBat state updated to OFF
2016-02-07 19:19:50 - BD_Tuer_State state updated to false
openhab.log
2016-02-07 19:19:49.110 [INFO ] [org.openhab.model.script.FILE ] - Bad: Türsensor ausgelöst: true
2016-02-07 19:19:50.707 [INFO ] [org.openhab.model.script.FILE ] - Bad: Türsensor ausgelöst: false
As you can see, I am not getting past the point of checking the state. I tried comparing with 1/true/ON
as well without success - even though the state clearly switches to true
The following rule conditon is even worse. The rule is not executed at all:
Item BD_Tuer_State changed from CLOSED to OPEN
On a logical level, everything seems correct, what am I doing wrong?
Thanks! Thomas
(System: RPi2 + homegear + openhab 1.8.1)
