I’m having trouble with debug logging in my rules. I’ve searched the forums and google endlessly and still can’t get it to work, looking for some assistance. I’m fairly new to Openhab…
I’m running openhab in debug mode (start_debug) on Windows.
I added the following line to my logback_debug.xml
<logger name="org.openhab.model.script.tempdebug" level="DEBUG"/>
I created a sample to verify my debugging is working correctly:
rule "temp" logDebug("tempdebug","Temptoohigh Rule start") var timer = 0 when logDebug("tempdebug","Temptoohigh Rule when") system started then logDebug("tempdebug","Temptoohigh Rule then") var timer = 1 end
When checking my openhab log file, I see that the rule is loaded, but no indication that the debug statements are logged. My complete logback_debug file is posted below. Any thoughts on why the logDebug statements for “tempdebug” are not appearing in the log? Thanks!
<appender name="STDOUT" class="ch.qos.logback.core.ConsoleAppender">
<encoder>
<pattern>%d{HH:mm:ss.SSS} [%-5level] [%-30.30logger{36}:%-5line] - %msg%n</pattern>
</encoder>
</appender>
<appender name="FILE" class="ch.qos.logback.core.FileAppender">
<file>${openhab.logdir:-logs}/openhab.log</file>
<encoder>
</encoder>
</appender>
<appender name="EVENTFILE"
class="ch.qos.logback.core.rolling.RollingFileAppender">
<file>${openhab.logdir:-logs}/events.log</file>
<rollingPolicy class="ch.qos.logback.core.rolling.TimeBasedRollingPolicy">
<!-- weekly rollover and archiving -->
<fileNamePattern>events-%d{yyyy-ww}.log.zip</fileNamePattern>
<!-- maximum number of archive files to keep -->
<maxHistory>30</maxHistory>
</rollingPolicy>
<encoder>
<pattern>%d{yyyy-MM-dd HH:mm:ss} - %msg%n</pattern>
</encoder>
</appender>
<logger name="runtime.busevents" level="INFO" additivity="false">
<appender-ref ref="EVENTFILE" />
<appender-ref ref="STDOUT" />
</logger>
<logger name="org.openhab" level="DEBUG" />
<logger name="org.openhab.binding.knx" level="DEBUG" />
<logger name="org.openhab.binding.onewire" level="INFO" />
<logger name="org.openhab.ui" level="INFO" />
<logger name="org.openhab.ui.webapp" level="DEBUG" />
<logger name="org.openhab.ui.webapp.internal.servlet" level="INFO" />
<logger name="org.openhab.io.net" level="INFO" />
<logger name="org.openhab.core.autoupdate" level="DEBUG" />
<logger name="org.openhab.core.persistence.internal" level="TRACE" />
<logger name="org.openhab.core.transform.internal.service.MapTransformationService" level="INFO" />
<logger name="org.openhab.binding.vdr" level="DEBUG" />
<logger name="org.openhab.model.core.internal.folder" level="INFO" />
<logger name="org.openhab.io.dropbox" level="DEBUG" />
<logger name="OSGi" level="WARN" />
<logger name="org.eclipse.jetty" level="WARN" />
<!-- temporary workaround for https://github.com/openhab/jupnp/issues/9 -->
<logger name="javax.jmdns.impl.DNSIncoming" level="ERROR"/>
<!-- temporary workaround for https://bugs.eclipse.org/bugs/show_bug.cgi?id=402750 -->
<logger name="OSGi" level="OFF" />
<logger name="tuwien.auto.calimero" level="WARN" />
<root level="ERROR">
<appender-ref ref="FILE" />
<appender-ref ref="MYAUTOMATION" />
</root>
