I’m using openHAB 2.0 snapshot from earlier this month. I have rules configured to update a DateTime item when a switch’s state changes. The DateTime update is not working, so I’m now attempting to add some log debugging, but I can’t get that to work either.
My rule:
rule "Update N00014_PRS_Switch"
Item N00014_PRS_Switch changed
logDebug("PRS","N00014 changed")
postUpdate(N00014_PRS_Time, new DateTimeType())
logDebug("PRS","N00014 time updated")
I’ve set the log level for PRS to debug via: log:set DEBUG org.eclipse.smarthome.model.script.PRS
but I don’t see any log info when tailing that log.
You cannot have a log statement in the when clause of the rule. I would expect to see errors in the openhab.log file indicating it couldn’t parse the .items file. But even without the error, the above is not syntactically correct so as far as OH is concerned the rule does not exist.
Just move the first logDebug statement after the then and it should work.
If you would have moved the first logInfo to the position just after the “then”, you would see that logInfo in the log.
What is “new” support to be, a typo? Shouldn’t that be “now” ? And I’m not sure about the syntax you are using here, I’d declare the time variable before, set it to now ( if that is what you want) and use it after that in the postupdate.
Please try out the method, as I’m not sure, if the action would cast the correct type.
N00014_PRS_Time is of type DateTime?
N00014_PRS_Time.postUpdate(new DateTimeType())
which I want to use in a rule and see some log output. Some how I can not figure this out. My rule:
rule "Living Switch"
Item Switch_Living changed
logDebug("living", "Kitchen light turned on")
logInfo("living", "test")
rule "Test Timer"
Time cron "0 0/1 * * * ?"
logInfo("living","Timer one Minute")
Addtionally I added an timer every Minute log. But neither is showing when I go to
ssh openhab@localhost -p 8101
and enter
log:tail
Follwing addtional Info:
openhab> log:get
Logger | Level
ROOT | INFO
But I entered:
openhab> log:set INFO org.eclipse.smarthome.model.script.living
