i am trying to set up a rule depending the state of a switch and the time now (compared to a time from the astro binding).
What the rule should do:
- If the switch is on, everything should be turned of at the trigger
- If the switch is on an time is before sunset, just the tuner should be turned on
- If the switch is on an time is after sunset, the tuner and some lights should be turned on
this is my actual rule, but it doenst work, i get this warning in the console:
18:45:13.158 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model 'dashbuttons.rules' has errors, therefore ignoring it: [15,59]: no viable alternative at input '&&'
rule "Dash button pressed"
Channel "amazondashbutton:dashbutton:xx-xx-xx-xx-xx-xx:press" triggered
var SunSetTime = (AstroSunData_Set_StartTime.state as DateTimeType).calendar.timeInMillis
if(ZW_Steckdose_Wohnzimmer_Media_Switch.state == ON) {
sendCommand(Group_Lichter, OFF)
sendCommand(YamahaReceiverRXV775_Power, OFF)
createTimer(now.plusSeconds(1)) [| sendCommand(LgTv_Poweroff, ON) ]
createTimer(now.plusSeconds(10)) [| sendCommand(ZW_Steckdose_Wohnzimmer_Media_Switch, OFF) ]
createTimer(now.plusSeconds(1)) [| sendCommand(LgTv_Poweroff, OFF) ]
if(ZW_Steckdose_Wohnzimmer_Media_Switch.state == OFF) && (now.isAfter(SunSet_Time)) {
sendCommand(ZW_Steckdose_Wohnzimmer_Media_Switch, ON)
createTimer(now.plusSeconds(20)) [| sendCommand(YamahaReceiverRXV775_Power, ON) ]
createTimer(now.plusSeconds(4)) [| sendCommand(YamahaReceiverRXV775_InputSource, 'TUNER')]
if(ZW_Steckdose_Wohnzimmer_Media_Switch.state == OFF) !! (now.isAfter(SunSet_Time)) {
sendCommand(Group_Wohnzimmer_Licht, ON)
thanks for your help!
Alex
