Not have been in debug mode, yet, just happy, that everything works again. ![]()
But I will try later.
When I am experiencing the following errors, once I restart the automation bundle:
2025-01-26 15:52:48.719 [ERROR] [e.automation.internal.RuleEngineImpl] - Failed to compile rule ‘szenen_schlafzimmer-1' with status 'UNINITIALIZED'
2025-01-26 15:52:48.720 [ERROR] [e.automation.internal.RuleEngineImpl] - Failed to compile rule ‘kamin-2' with status 'UNINITIALIZED'
2025-01-26 15:52:48.720 [ERROR] [e.automation.internal.RuleEngineImpl] - Failed to compile rule ‘waschmaschine-1' with status 'UNINITIALIZED'
2025-01-26 15:52:48.720 [ERROR] [e.automation.internal.RuleEngineImpl] - Failed to compile rule ‘badezimmer-1' with status 'UNINITIALIZED'
2025-01-26 15:52:48.721 [ERROR] [e.automation.internal.RuleEngineImpl] - Failed to compile rule ‘rollladen-2' with status 'UNINITIALIZED'
2025-01-26 15:52:48.721 [ERROR] [e.automation.internal.RuleEngineImpl] - Failed to compile rule ‘rollladen-1' with status 'UNINITIALIZED'
2025-01-26 15:52:48.725 [ERROR] [e.automation.internal.RuleEngineImpl] - Failed to execute rule ‘general-1' with status 'UNINITIALIZED'
2025-01-26 15:52:48.727 [INFO ] [e.automation.internal.RuleEngineImpl] - Rule engine started.
Seems to be a similar issue as here:
Just found the thread after searching for the error message…
