p912s
(Scot)
1
Hello!
After researching rules/switches I’ve created a couple of rules that seem to work. That is, they execute a command, but my thermostat isn’t changing.
These are the buttons I’m pushing.
Commented within my rules I have the commands that work from a command prompt.
rule “Hold Disabled”
Item Tstat_hold received command 0
// command line: curl -d ‘{“hold”:0}’ http://192.168.224.50/tstat
executeCommandLine(“curl -d ‘{"hold":0}’ http://192.168.224.50/tstat”)
rule “Hold Enabled”
Item Tstat_hold received command 1
// command line: curl -d ‘{“hold”:1}’ http://192.168.224.50/tstat
executeCommandLine(“curl -d ‘{"hold":1}’ http://192.168.224.50/tstat”)
Watching the monitor connected to the Pi I see the following when clicking the No button.
executed CommandLine ‘curl -d ‘{“hold”:1}’ http://192.168.224.50/tstat’
But the thermostat doesn’t change.
Is there something wrong in my command?
Thanks!
Scot
Dibbler42
(Thomas Bail)
2
I assume that the command will work from the commandline itself. Maybe you have to use the fullqualifies path to curl like /usr/bin/whatever/curl
Thomas
p912s
(Scot)
3
Yes it works from the command line.
Thanks for the thought on using the full path, gave it a try, but unfortunately it didn’t work.
david
(david)
6
See this link where I am sending an HTTP POST to the thermostat.
