Rule execution lags, possibly Java GC
Nope. In each rules file that seems to be affected by “swapping out” of rules, you add another rule with a periodic cron trigger, that does nothing much. The theory is that keeping that rule active also stops other rules being swapped out of memory.
Be careful if applying to multiple rule files, to keep every rule “name” unique.
