I’ve got several lighting scenes, one of them is for watching TV, that in your case would inactivate your motion triggers.
I’m also querying my receiver via HTTP binding so I changed to that scene automatically when the receiver becomes active.
don’t know what you mean. Use a virtual item “scene” of number type, manually or automatically set it to ‘5’ or whatever number you assign to your TV scene, then in all rules to trigger on motion detectors, insert an if statement and only change lights if scene != 5.
My rules are way more complex so I don’t show them.
I created a movie mode item when this is on none of my lighting rules can run
You manually turn on movie mode it turns lights off and blocks any lighting changes until movie mode is disabled
I set mine too turn lights off and they come back on if you pause or stop what your watching you could make them do anything (my movie mode moniters a kodi machine for play pause and stop)
Movie mode on turns lights off blocks changes
Movie mode paused brings lights back on in a dimmed state still blocks changes as movie mode still enabled
Movie mode stop disables movie mode changes lights too normal and allows all changes again
My lighting rules have an if statement if movie mode is off change lights ect of on do nothing
My setup is slightly different than yours my lighting throughout the house is also triggerd by motion but the living room sensor where we watch movies is only for motion it does not turn the lights on or off
My living room lighing is ran by rules at certain times of the day do this too a light
Rule "lights"
When
Item motion changed to ON
Then
If (moviemode.state == OFF) {
//DO LIGHTS STUFF
End
Or you could do what you were stating replace the if moviemode.state with receiver.state or tv.state
Thanks @Sharpy do you know how it would be possible to disable the motion sensor on the Fibaro Motion sensor zwave unit? by disable as in ignore any events from it.
var Timer Eye1_Timer = null
val Integer Eye1_TimeOut = 2
rule "FibaroEye1 motion detection turns ON Living Room Lights when Lux is less than 20, with a 2 Minute Inactivity Timer"
Item FibaroEye1Alarm changed to ON
if (FibaroEye1Lux.state < 20) {
if (Eye1_Timer !== null) {
LivingRoomDim1.sendCommand("5")
logInfo("FibaroEye1Motion","Eye1 Timer rescheduled for " + Eye1_TimeOut + " minutes")
Eye1_Timer.reschedule(now.plusMinutes(Eye1_TimeOut))
} else {
logInfo("FibaroEye1Motion", "Eye1 Motion Detected! Turning ON Living Room Lights")
logInfo("FibaroEye1Motion","Eye1 Timer created with " + Eye1_TimeOut + " minutes")
Eye1_Timer = createTimer(now.plusMinutes(Eye1_TimeOut))
if (FibaroEye1Alarm.state == ON) {
logInfo("FibaroEye1Motion","Eye1 Timer triggered, but rescheduled again for " + Eye1_TimeOut + " minutes")
} else {
logInfo("FibaroEye1Motion", "Eye1 No Motion Detected! Turning OFF Living Room Lights")
LivingRoomSw1.sendCommand("OFF")
Eye1_Timer = null
Ok I’m not 100% sure your rules are slightly more advanced than mine
This is what turns your lights on when motion is detected?
but creating the item moviemode that you can turn on from basicui or habpannel when you are watching a movie and add an if moviemode.state == OFF too this section it will stop the lights from turning on when movie mode is on
Item
Switch Moviemode "Movie Mode"
Rule
If (moviemode.state == OFF ) {
if (FibaroEye1Lux.state < 20 && Scene_Watch_Netflix == OFF) {
} else {
} else {
Eye1_Timer = null
Im still making some changes to the Scene, basically I’m having issues with TV presense detection which is causing the rule to not execute the Input button in my rule.
I think the way you have changed your rule adding watch netflix nothing will work if watch netflix is on you might need too place it only where it turns lights on so the rest of the rule can still run
If lux is above 20 or netflix is on none of your rule will work?
