I am trying to control a light based on the sun elevation.
So not only using the sun rise and set triggers, but if elevation changes from < 10 ° to >= 10 °, then get brighter.
Is there a way to accomplish this in the webinterface - Using the ‘next gen’ rules?
I’m using openhab 3.2 in docker and this type of rules at least gets presented as the way it should be done.
However i put the ‘from state’ and ‘to state’ (With “| °” or without and some variations) it does not seem to work
Might look something like this:
configuration: {}
triggers:
- id: "1"
configuration:
itemName: LocalSun_Position_Elevation
previousState: < 10.0 °
state: ">= 10.0 °"
conditions: []
actions:
- id: "2"
configuration:
itemName: IkeaLEDDriver_ZLL_DIMMABLE_LIGHTLevelControl
command: "40"
type: core.ItemCommandAction
Any advice on how to accomplish this?
rossko57
(Rossko57)
January 24, 2022, 4:25pm
2
Your elevation Item probably has units - degrees, radians. Comparing with 10 whatever’s is not computable.
I don’t think the trigger handles units? So you would trigger on any change and compare in script section.
Can i move that part to the conditions section?
Like this:
conditions:
- inputs: {}
configuration:
state: 10 °
operator: ">="
type: core.ItemStateCondition
if yes, how would i go about transforming the Number:Angle to an Int that i can compare?
After that’s done for the current state, how can i access the previousState in the conditions block?
rossko57
(Rossko57)
January 24, 2022, 4:34pm
4
I wouldn’t expect that to work any better than triggers.
But you can script a condition, and scripts can compare quantities with units.
How-to access previousState depends on the scripting language.
rlkoshak
(Rich Koshak)
January 24, 2022, 4:35pm
5
A rule triggers on events, not conditions. You can not use comparisons in a rule trigger.
You need to add conditions to compare the state with 10.0 °. If you want to compare the previous state as well, you need to use a script condition.
As of 3.2, UI rule conditions are units aware now. It will work without units but complain in the logs with a warning that you should add the units.
CHTHSCH
(Thomas Schmidt)
January 24, 2022, 5:36pm
6
I am using the elevation of the sun to control my blinds, perhaps you find some useful input in the attached script.
Note: I have converted the rules script from openHAB 2.5
configuration: {}
triggers:
- id: "1"
configuration:
itemName: MagenwilSonnendaten_Azimut
conditions: []
actions:
- inputs: {}
configuration:
type: application/vnd.openhab.dsl.rule
script: >-
var int Sonnenstand = (MagenwilSonnendaten_Azimut.state as
Number).intValue
var Winkel = (MagenwilSonnendaten_Position_Elevation.state as Number).floatValue
if ( Winkel >= 3 && Sonnenstand >= 60 && Sonnenstand <= 155 ) {
if ( Sonnenschutz_Ost.state != ON ) Sonnenschutz_Ost.postUpdate(ON)
} else {
Sonnenschutz_Ost.postUpdate(OFF)
if ( Winkel >= 3 && Sonnenstand >= 80 && Sonnenstand <= 195 ) {
if ( Sonnenschutz_Bibliothek.state != ON ) Sonnenschutz_Bibliothek.postUpdate(ON)
} else {
Sonnenschutz_Bibliothek.postUpdate(OFF)
if ( Winkel >= 3 && Sonnenstand >= 80 && Sonnenstand <= 245 ) {
if ( Sonnenschutz_Sued.state != ON ) Sonnenschutz_Sued.postUpdate(ON)
} else {
Sonnenschutz_Sued.postUpdate(OFF)
if ( Sonnenschutz_Schlafzimmer.state != ON ) Sonnenschutz_Schlafzimmer.postUpdate(ON)
} else {
Sonnenschutz_Schlafzimmer.postUpdate(OFF)
if ( Winkel >= 3 && Sonnenstand >= 260 && Sonnenstand <= 305 ) {
if ( Sonnenschutz_Kueche.state != ON ) Sonnenschutz_Kueche.postUpdate(ON)
} else {
Sonnenschutz_Kueche.postUpdate(OFF)
logInfo("Rule Engine", "Jahreszeit : {}", MagenwilSonnendaten_Jahreszeit.state)
logInfo("Rule Engine", "Sonnenwinkel: {}", Winkel)
logInfo("Rule Engine", "Azimut : {}", Sonnenstand)
logInfo("Rule Engine", "Sonnenschutz Wohnzimmer Ost: {}", Sonnenschutz_Ost.state.toString)
logInfo("Rule Engine", "Sonnenschutz Wohnzimmer Süd: {}", Sonnenschutz_Sued.state.toString)
logInfo("Rule Engine", "Sonnenschutz Bibliothek : {}", Sonnenschutz_Bibliothek.state.toString)
logInfo("Rule Engine", "Sonnenschutz Schlafzimmer : {}", Sonnenschutz_Schlafzimmer.state.toString)
logInfo("Rule Engine", "Sonnenschutz Küche : {}", Sonnenschutz_Kueche.state.toString)
type: script.ScriptAction
