Although in event log the state of the item is changed, my rule is not triggered. I’m looking at this for a couple of days, and I just can’t figure it out.
When there is motion (detected by “mot_BePodMeetingRoom_Lights”), the lights (named “dim_BePod_Dim1_MeetingRoom”) should be switched on.
Can you help me ? – Ivan
bepod.rules
rule "Switch lights in meeting room"
Item mot_BePod_MeetingRoom_Lights changed
val switch1 = if(stat_Bravia.state == "ON") OFF else ON
dim_BePod_Dim1_MeetingRoom.sendCommand(mot_BePod_MeetingRoom_Lights.state)
dim_BePod_Dim1_TV.sendCommand(switch1)
events.log
2017-10-04 17:23:02.472 [ItemStateChangedEvent ] - mot_BePod_MeetingRoom_Lights changed from OFF to ON
2017-10-04 17:23:02.473 [ItemCommandEvent ] - Item 'mot_BePod_MeetingRoom_Lights' received command ON
2017-10-04 17:23:02.501 [ItemCommandEvent ] - Item 'mot_BePod_MeetingRoom_AV' received command ON
2017-10-04 17:23:02.573 [ItemStateChangedEvent ] - mot_BePod_MeetingRoom_AV changed from OFF to ON
2017-10-04 17:32:26.325 [ItemCommandEvent ] - Item 'mot_BePod_MeetingRoom_Lights' received command ON
2017-10-04 17:32:26.357 [ItemCommandEvent ] - Item 'mot_BePod_MeetingRoom_AV' received command ON
2017-10-04 17:33:48.452 [ItemStateChangedEvent ] - mot_BePod_MeetingRoom_Lights changed from ON to OFF
2017-10-04 17:33:48.453 [ItemCommandEvent ] - Item 'mot_BePod_MeetingRoom_Lights' received command OFF
2017-10-04 17:33:48.482 [ItemCommandEvent ] - Item 'mot_BePod_MeetingRoom_AV' received command OFF
2017-10-04 17:33:48.554 [ItemStateChangedEvent ] - mot_BePod_MeetingRoom_AV changed from ON to OFF
bepod.items
Dimmer dim_BePod_Dim1_MeetingRoom "Vergaderzaal [%s]" (grpBePod, Lights) {knx="1/1/1+1/1/5, 1/1/3, 1/1/7+1/1/5"}
Dimmer dim_BePod_Dim1_TV "TV [%s]" (grpBePod, Lights) {knx="1/1/2+1/1/6, 1/1/4, 1/1/8+1/1/6"}
Switch mot_BePod_MeetingRoom_AV "Beweging verg.zaal voor A/V te schakelen" {knx="<4/0/0"}
Switch mot_BePod_MeetingRoom_Lights "Beweging verg.zaal voor licht te schakelen" {knx="<0/6/3"}
String stat_Bravia { channel="exec:command:bravia-status:output" }
