Rule is not working
Hello everyone,
I am trying to create a reule based on a onewireGPIO Temperture sensor.
The Rule is as follows:
Blockquote
Item TemperatureSensor_Temperature changed
if (TemperatureSensor_Temperature.state < 10) {
Relais8.sendCommand(OFF)
if (TemperatureSensor_Temperature.state > 25) {
Relais8.sendCommand(ON)
Blockquote
However i recieve the follwoing errormessage in the log:
Configuration model ‘Temp.rules’ is either empty or cannot be parsed correctly!
Hope you can get me a hint where i might have to look for the error.
Need the add “rule” to the top.
Example
rule "Your Rule"
Please use the code fences when publishing code in the forum, please
Also, rules syntax documentation:
and
@Soron I edited your topic category from tutorial to the above.
