rule "KucheLichtAuto"
Thing "hue:0100:xxxxxxxxxxx:2" changed or
Item SunElevation changed or
Item Kuchenlicht changed
var status = ThingAction.getThingStatusInfo("hue:0100:xxxxxxxxxxx:2").getStatus()
if (status.toString() == 'ONLINE' || SunElevation.state > 0 || Kuchenlicht.state == ON ) {
sendCommand(Gateway_Licht, OFF)
else if (Kuchenlicht.state == OFF || SunElevation.state < 0) {
sendCommand(Gateway_Licht, ON)
What I want:
Turn ON the Gateway_Light if the SunElevation is lower than 0
Turn ON the Gateway_Light if the Kuchenlicht is OFF and SunElevation is lower than 0
Turn OFF the Gateway_Light if the Kuchenlicht is ON even if SunElevation is lower than 0
Turn OFF the Gateway_Light if the SunElevation is higher than 0
I’m pretty certain this is not valid. Rules do not work with Things directly except in a couple very specific ways, and this isn’t one of those ways.
But even if it were valid as written, it is redundant with Item Kuchenlicht changed because that Item is linked to the Thing.
What you have for the logic is mostly reasonable. I would probably order things a little differently as I like to avoid really long if statements when I can.
// log warning if the Kuchenlicht is offline and do nothing
if(ThingAction.getThingStatusInfo("hue:0100:xxxxxxxxxxx:2").getStatus().toString != "ONLINE") {
logWarn("light", "The Kuchenlicht is not ONLINE!, cannot perform KucheLichtAuto")
return;
val gatewayState = ON // default to ON
// If the Kuchenlicht is ON or the SunElevation > 0 turn OFF
if(Kuchenlicht.state == ON || SunElevation.state as Number > 0) gatewayState = OFF
// Only send the command if the new state is different from the current state
if(Gateway_Licht.state != gatewayState) Gateway_Licht.sendCommand(gatewayState)
Thank you very much for your code and way to do it!
I get an info at my log. Should I ignore it?
22:20:17.867 [INFO ] [del.core.internal.ModelRepositoryImpl] - Validation issues found in configuration model 'myrules.rules', using it anyway:
Assignment to final variable
About to get the Gateway_LightON if Thing “hue:0100:xxxxxxxxxxx:2”OFFLINE, I set it like here:
if(Kuchenlicht.state == OFF || SunElevation.state as Number < 0) gatewayState = ON
But there is an error in log
22:20:27.722 [WARN ] [del.core.internal.ModelRepositoryImpl] - Configuration model 'myrules.rules' has errors, therefore ignoring it: [98,67]: no viable alternative at input '0'
rule "KucheLichtOffline2"
logWarn("light", "The Kuchenlicht is OFFLINE!, cannot perform KucheLichtAuto")
//return;
var gatewayState = ON // default to ON
Logic:
Well the GatewayLight should go ON if Thing or Kuchenlicht is OFFLINE or SunElevation is lower than 0.
GatewayLight goes OFF if Kuchenlicht is ON and SunElevation is higher than 0.
Explain:
During the day I do not need the GatewayLight, so it should be OFF anyway.
After the Sun is set (SunElevation is lower than 0), if the Thing is OFFLINE (Switched off by the Wallswitch) or Kuchenlicht is OFF (Thing is ONLINE) or anyway if SunElevation is lower than 0 than it GatewayLight should be ON.
By that way I have a small light point in the dark and goes off if I act somehow.
I get the point that it will not run if the Thing is OFFLINE but need to act even if is not ONLINE. Than the part above will not work anyway if is OFFLINE.
So my original rule turns off the light if the Kuchenlicht is ON or if the SunElevation is higher than 0. All other cases turn ON the light. So at best the following line is redundant but in this case it won’t work at all because you need an and, not an or.
Put in words:
if Kuchenlicht.state is ON, gatewayState = OFF. If Kuechenlicht.state != ON AND SunElevevation.state as Number > 0, gatewayState = OFF. In ALL other situations gatewayState = ON.
