- Platform information:
- Hardware: Raspberry Pi 3
- OS: OpenHABian
- openHAB version: 3.0.2
I have created 2 test rules for my 2 Nest thermostats. One rule sends a command to cycle ON the HVAC for one thermostat. The other rule is supposed to be triggered by the thermostat cycling on, and is supposed to cycle OFF the other thermostat and run a script to change its setpoint (so that it doesn’t immediately just cycle back on).
The first rule is as follows:
triggers: []
conditions: []
actions:
- inputs: {}
configuration:
itemName: Downstairs_Status
command: COOLING
type: core.ItemCommandAction
The second rule is:
triggers:
- id: "1"
configuration:
command: cooling
type: core.ItemCommandTrigger
conditions: []
actions:
- inputs: {}
configuration:
type: application/vnd.openhab.dsl.rule
script: >-
logInfo("TEST Reset Upstairs - Start", "Detected Downstairs cycling on.
Attempting to reset Upstairs_Setpoint. Current setpoint state = " +
Upstairs_Setpoint.state)
var setpoint = (Upstairs_Setpoint.state as QuantityType<Number>).toBigDecimal
var offset = (DR_Cooling_Offset_degF.state as QuantityType<Number>).toBigDecimal
setpoint = setpoint + offset
if (setpoint > 90.0)
logInfo("TEST Reset Upstairs [WARNING]", "new setpoint (" + setpoint + ") may be higher than the max cooling setpoint allowed by the thermostat. The change may not take effect.")
sendCommand(Upstairs_Setpoint, setpoint)
logInfo("TEST Reset Upstairs - End", "Finished resetting Upstairs_Setpoint. New setpoint state = " + Upstairs_Setpoint.state)
type: script.ScriptAction
- inputs: {}
configuration:
itemName: Upstairs_Status
command: OFF
When I run the first rule, I would expect that the 2nd rule would trigger and turn off the other othermostat. But nothing happens. The Downstairs tstat shows that it cycles to COOLING, but the item states for the Upstairs tstat do not change in the OpenHAB portal, nor does the actual thermostat reset.
I checked the logs (from /var/log/openhab/openhab.log on the PRi), and it doesn’t show anything. There are no errors, but none of my info statements are logged. It looks like rule 2 is never running.
If I manually run rule 2 (by clicking the “play” icon button in the rule Design screen), it does correctly change the cycle of the tstat and reset its setpoint. All my log statements show up in the log if I run it manually. So I don’t think there’s a problem with the rule itself; it just isn’t getting triggered by its respective trigger.
Do I have something configured wrong? Why isn’t this 2nd rule triggering?
Upstairs_Status and Downstairs_Status are both items that are linked to the respective tstat’s “HVAC Status” channel, and Upstairs_Setpoint is an item that is linked to both the upstairs tstat’s “Cool Temperature” and “Target Temperature” channels. Should I only link setpoint to one or the other, but not both?
