Hi folks,
I’ve struck a simple problem that I just can’t solve. I’ve checked all similar forum posts I can find.
Problem Description:
Platform information:
Hardware:
| Model Name: Mac mini
| Model Identifier: Macmini6,1
| Processor Name: Intel Core i5
| Processor Speed: 2.5 GHz
| Number of Processors: 1
| Total Number of Cores: 2
| L2 Cache (per Core):256 KB
| L3 Cache: 3 MB
| Memory: 16 GB -
OS: Apple OS X
System Version: macOS 10.13.6 -
Java Runtime Environment: Oracle Java version 8 release 181
openHAB version: 2.3 stable
Issue of the topic:
A rule that should fire when any button on a zwave Wallmote is pressed has just stopped firing. I have a CRON based rule to check heater status on a nightly basis which does fire. I have tried restarting openHAB and rebooting the system. No change. I have tried refreshing both the item and rule files to try and restart the rule. There are no errors relating to this issue that I can see in the logs. I do get an intermittent error:
22:55:54.147 [ERROR] [ng.nest.handler.NestThermostatHandler] - Unsupported channelId 'time_to_target_mins'
- However I’ve had this issue for some time, I know what this error is and how to fix it, and it hasn;t caused an issue so far. Attached is the item configuration for the Wallmote (WM01_scene). When a button is pressed, log entries show “WM01_scene changed from…” but the rule “wallmote01_scenes” doesn’t fire. It used to. I had changed nothing on this system, it has been running openHAB, Splunk and pi-hole (in a docker container) successfully for some time. It is only used as a server for these applications.
Any assistance would be greatly appreciated. Thanks.
- Item configurations relating to wallmote and controlled devices:
Number WM01_scene "WallMote 01 Scene: [%s]" <contact> {channel="zwave:device:0c63a48b:node13:scene_number"}
Switch lamp_right_upstairs "Right Upstairs Lamp" <light> ["Lighting"] {channel="zwave:device:0c63a48b:node11:switch_binary"}
Switch lamp_left_upstairs "Left Upstairs Lamp" <light> ["Lighting"] {channel="wemo:insight:Insight-1_0-221520K12003B7:state"}
- Rules code related to the issue
var String FRU_last_dim_state
var Number dimmer_offset = null
//FRU = Family Room Upper
rule "wallmote01_scenes"
Item WM01_scene received update
logInfo("wallmote.rules", "wallmote rule triggered")
logInfo("wallmote.rules", "wallmote scene number: " + WM01_scene.state)
logInfo("wallmote.rules", "wallmote right lamp state: " + lamp_right_upstairs.state)
logInfo("wallmote.rules", "wallmote left lamp state: " + lamp_left_upstairs.state)
logInfo("wallmote.rules", "wallmote family room upper state: " + light_family_room_upper.state)
logInfo("wallmote.rules", "FRU_last_dim_state: " + FRU_last_dim_state)
logInfo("wallmote.rules", "dimmer_offset: " + dimmer_offset)
switch(WM01_scene.state) {
// Upstairs Left Lamp ON/OFF
case 1.0 : {
if (lamp_left_upstairs.state == OFF) {
logInfo("wallmote.rules", "scene state: 1.0 and lamp off, turn lamp ON")
lamp_left_upstairs.sendCommand(ON)
else {
logInfo("wallmote.rules", "scene state: 1.0 and lamp on, turn lamp OFF")
lamp_left_upstairs.sendCommand(OFF)
// Upstairs Right Lamp ON/OFF
case 2.0 : {
if (lamp_right_upstairs.state == OFF) {
logInfo("wallmote.rules", "scene state: 2.0 and lamp off, turn lamp ON")
lamp_right_upstairs.sendCommand(ON)
else {
logInfo("wallmote.rules", "scene state: 2.0 and lamp on, turn lamp OFF")
lamp_right_upstairs.sendCommand(OFF)
// Family Room Upper Dimmer implementation
case 3.0 : {
// If Off turn ON - single short press
if (light_family_room_upper.state == 0) {
logInfo("wallmote.rules", "scene state: 3.0 and FRU off, turn FRU ON")
light_family_room_upper.sendCommand(ON)
// If ON turn OFF - single short press
else {
logInfo("wallmote.rules", "scene state: 3.0 and FRU on, turn FRU OFF")
light_family_room_upper.sendCommand(OFF)
// set the last dim state so that next time do the opposite.
case 3.1 : {
if(FRU_last_dim_state == "up"){
FRU_last_dim_state = "down"
else {
FRU_last_dim_state = "up"
case 3.2 : {
//Dimmer Up - long press
if (light_family_room_upper.state < 255 && (FRU_last_dim_state == "down" || FRU_last_dim_state === null)) {
logInfo("wallmote.rules", "scene state: 3.2 and FRU on, dimmer light up")
if(dimmer_offset === null){
dimmer_offset = (255 - (light_family_room_upper.state as Number))/30
light_family_room_upper.sendCommand((light_family_room_upper.state as Number) + dimmer_offset)
logInfo("wallmote.rules", "light_level: " + light_family_room_upper.state)
// Dimmer down - long press
else {
dimmer_offset = ((light_family_room_upper.state as Number))/30
} light_family_room_upper.sendCommand((light_family_room_upper.state as Number) - dimmer_offset)
// Double short press for full brightness
logInfo("wallmote.rules", "wallmote rule complete")
- Logs showing refesh of items and rules file with no errors, and the wallmote event.
22:08:07.148 [INFO ] [.internal.service.FeaturesServiceImpl] - Adding features:
22:08:07.695 [INFO ] [.internal.service.FeaturesServiceImpl] - No deployment change.
22:08:07.699 [INFO ] [.internal.service.FeaturesServiceImpl] - Done.
22:08:24.070 [INFO ] [del.core.internal.ModelRepositoryImpl] - Refreshing model 'wallmote.items'
22:08:34.932 [INFO ] [del.core.internal.ModelRepositoryImpl] - Refreshing model 'wallmote.rules'
22:08:40.027 [INFO ] [org.quartz.core.QuartzScheduler ] - Scheduler openHAB-job-scheduler_$_NON_CLUSTERED started.
22:08:58.569 [INFO ] [smarthome.event.ItemStateChangedEvent] - WM01_scene changed from 3.0 to 2.0
22:09:07.148 [INFO ] [.internal.service.FeaturesServiceImpl] - Adding features:
22:09:07.773 [INFO ] [.internal.service.FeaturesServiceImpl] - No deployment change.
22:09:07.777 [INFO ] [.internal.service.FeaturesServiceImpl] - Done.
