I have a water leak sensor connected to Obenhab through ZigbeetoMqtt.
The sensor reports a water leak as either “true” or “false”. I have set this item up in my items file:
String RyTTER0_VANDALARM_ALARM_STRING "Vandalarm" (Zigbee) {mqtt="<[MPmqtt:zigbee2mqtt-rytterstue/VandalarmRytterstue:state:JSONPATH($.water_leak)]"}
It works and receives messages from the sensor. I have also made a switch item to use as the alarm (on/off):
Switch RyTTER0_VANDALARM_ALARM
To change the switch according to the message from the sensor I have made this rule:
rule "Vandalarm"
Item RyTTER0_VANDALARM_ALARM_STRING changed
if(RyTTER0_VANDALARM_ALARM_STRING.state == true){
RyTTER0_VANDALARM_ALARM.sendCommand(ON)
else{
RyTTER0_VANDALARM_ALARM.sendCommand(OFF)
The rule receive the update from the string vaiable and starts up but always ends with sending a command(off) to the switch. What am I missing here?
