I’m getting the Message Rule … null wihtin a rule of the telegram binding. Either I’m blind or something is very strange because in my opionen, nothing is null.
Rules:
rule "TG Nachricht erhalten"
Item telegramMessageText received update
if (telegramReplyId.state != NULL) {
return;
val telegramAction = getActions("telegram","telegram:telegramBot:TelegramBot")
val chatId = Long::parseLong(telegramChatId.state.toString)
val text = telegramMessageText.state.toString
if (text=="/start") {
telegramAction.sendTelegramQuery(chatId, "Was möchtest du wissen", "startReply", "Fenster", "Anwesenheiten")
} else {
telegramAction.sendTelegram(chatId, "Echo: "+text)
rule "TG Reply erhalten"
Item telegramReplyId received update
logInfo("tg", "Start")
if (telegramReplyId.state == NULL) {
logInfo("tg", "Early Exist")
return;
logInfo("tg", "Kein Early Exist")
if (telegramAction === null) {
logInfo("tg", "Action Null")
return;
logInfo("tg", "Nach Action")
logInfo("tg", telegramAction.toString)
telegramAction.sendTelegramAnswer("startReply", "Antwort");
logInfo("tg", "Ende")
I’m sending to the telegram bot “/start” and answer the reply. Then, the following log output happens:
2020-11-15 17:37:00.506 [INFO ] [rg.eclipse.smarthome.model.script.tg] - Start
2020-11-15 17:37:00.517 [INFO ] [rg.eclipse.smarthome.model.script.tg] - Early Exist
2020-11-15 17:37:01.679 [INFO ] [rg.eclipse.smarthome.model.script.tg] - Start
2020-11-15 17:37:01.680 [INFO ] [rg.eclipse.smarthome.model.script.tg] - Kein Early Exist
2020-11-15 17:37:01.680 [INFO ] [rg.eclipse.smarthome.model.script.tg] - Nach Action
2020-11-15 17:37:01.680 [INFO ] [rg.eclipse.smarthome.model.script.tg] - org.openhab.binding.telegram.bot.TelegramActions@2c5d25ab
2020-11-15 17:37:01.964 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'TG Reply erhalten': null
As you can see, the last log messge (“Ende”) is never printed. But the line before get’s executed, as I recieve the answer. If I enable DEBUG for the telegram Binding, the log output changes to
2020-11-15 17:39:34.595 [INFO ] [rg.eclipse.smarthome.model.script.tg] - Start
2020-11-15 17:39:34.596 [INFO ] [rg.eclipse.smarthome.model.script.tg] - Early Exist
2020-11-15 17:39:34.711 [DEBUG] [binding.telegram.bot.TelegramActions] - Adding chatId MMMM, replyId startReply and messageId XXX
2020-11-15 17:39:35.761 [DEBUG] [ng.telegram.internal.TelegramHandler] - Received callbackId XXX for chatId MMMand replyId startReply
2020-11-15 17:39:35.767 [INFO ] [rg.eclipse.smarthome.model.script.tg] - Start
2020-11-15 17:39:35.767 [INFO ] [rg.eclipse.smarthome.model.script.tg] - Kein Early Exist
2020-11-15 17:39:35.767 [INFO ] [rg.eclipse.smarthome.model.script.tg] - Nach Action
2020-11-15 17:39:35.767 [INFO ] [rg.eclipse.smarthome.model.script.tg] - org.openhab.binding.telegram.bot.TelegramActions@2c5d25ab
2020-11-15 17:39:35.767 [DEBUG] [binding.telegram.bot.TelegramActions] - AnswerCallbackQuery for chatId MMM and replyId startReply is the callbackId XXX
2020-11-15 17:39:35.809 [DEBUG] [binding.telegram.bot.TelegramActions] - remove messageId NNN for chatId MMM and replyId startReply
2020-11-15 17:39:36.028 [DEBUG] [binding.telegram.bot.TelegramActions] - remove messageId null for chatId MMM and replyId startReply
2020-11-15 17:39:36.028 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'TG Reply erhalten': null
Any Idea what I can do?
