Rule Occasionally Misfires
Hi All,
Need help with a rule. The rule below dictates the state of the house. Problem is that occasionally when I press the ‘Wake Up’ command openhab sends the ‘Go to Bed’ command. This has happened using the mobile app and Habpanel. The strange thing is that this rule works 90% of the time. The problem only happens once every 2-3 weeks. Not a big deal except when it happens to people other than myself.
You can see in the events.log file that the scene received the command 3 (wakeup), but in the openhab.log file we see the log info showing that the the number 2 (gotobed) was triggered. A few minutes later I pressed the wakeup command again and it went through normally.
Does anyone have any idea on why this misfires?
Using:
openhab 2.3 on Raspberry Pi 3
java: Zulu Embedded 8.25.0.76
Items
Number	Scene_TV	"State: [MAP(scenes.map):%s]" <sofa>
Sitemap
Frame label="Activity" {
		Switch item=Scene_TV label="." mappings=[1="TV", 2="Bed", 3="WakeUp"]
From events.log
2018-08-02 05:47:29.489 [ome.event.ItemCommandEvent] - Item 'Scene_TV' received command 3
2018-08-02 05:47:29.543 [vent.ItemStateChangedEvent] - Scene_TV changed from 2 to 3
2018-08-02 05:50:25.987 [ome.event.ItemCommandEvent] - Item 'Scene_TV' received command 3
From openhab.log
2018-08-02 05:47:29.532 [INFO ] [.smarthome.model.script.Going to bed] - Have a good night
2018-08-02 05:47:29.542 [INFO ] [.smarthome.model.script.Stars are on] - Turning on Stars
2018-08-02 05:50:26.018 [INFO ] [model.script.Scene_TV set to wake up] - Rise and shine!
Rule
rule "House Scene Activity"
when Item Scene_TV received command
var Timer bedTimer = null
var Timer morningTimer = null
switch Scene_TV
	case Scene_TV.state==1 : //watching tv
		logInfo("Setting house scene to tv", "We're watching tv")
		sendCommand(LR_Lamp_Color, "0,0,10")
		sendCommand(Stairs1_Dimmer, 25)
		sendCommand(Kitchen_Lightstrip_Counter_Color, "253,100,50")
		sendCommand(Kitchen_Lightstrip_Top_Color, "123,100,50")
		sendCommand(Kitchen_Sink_Color, "253,100,50")
		if (TV_Lightstrip.state!=ON)
			logInfo("turning on tv light", "turning on tv light")
			sendCommand(TV_Lightstrip, ON)
		gWatchTV.members.forEach(s | if (s.state == ON) {
		gWatchTV.sendCommand(OFF) })
		Harmony_Current_Activity.sendCommand("Xbox")
	case Scene_TV.state==2 : //going to bed
		logInfo("Going to bed", "Have a good night")
		Harmony_Current_Activity.sendCommand("PowerOff")
		sendCommand(LR_Lamp_Color, "0,0,100")
		Entryway.sendCommand(ON)
		Stairs1_Dimmer.sendCommand(30)
		Thermo_HeatSetPoint.sendCommand(60)
		bedTimer = createTimer(now.plusMinutes(5))[|
		gBed.members.forEach(s | if (s.state==ON) {
			s.sendCommand(OFF)
	case Scene_TV.state==3 : //wakeup
		logInfo("Scene_TV set to wake up", "Rise and shine!")
	 	gWakeup.members.forEach(s | if (s.state==OFF)
				s.sendCommand(ON)
		gSKitchen.members.forEach(i | if (i.state==ON) {
			i.sendCommand(OFF)
		Scene_Kitchen.postUpdate(3)
		Harmony_Current_Activity.sendCommand("TV")
		morningTimer = createTimer(now.plusMinutes(5))[|
		Down_Bath.sendCommand(OFF)
    when Item Scene_TV changed
    Thread::sleep(x)
test what is the necessary time on you system.
Is it this issue? Mysterious delay in items being updated
If so, you can fix it with a Thread::sleep(500) at the start of the rule
I will. Thanks.
This issue occurs because you are checking the state of Scene_TV BEFORE it has actually updated after receiving a command. It can take a few milliseconds and by that time your rule is already running.
Change the case statements with the implicit variable receivedCommand should get rid of the problem without resorting to Thread::sleep which should be avoided if possible:
var sceneNumber = receivedCommand as Number
switch Scene_TV
	case sceneNumber==1 : //watching tv
	case sceneNumber==2 : //going to bed
			s.sendCommand(OFF)
	case sceneNumber==3 : //wakeup
				s.sendCommand(ON)
			i.sendCommand(OFF)
I will give this a try. Thanks for your help.
Didn’t know that - thank you
@vzorglub, I got a question here, should it not be:
switch sceneNumber  // instead of Scene_TV
	case 1 : //watching tv
	case 2 : //going to bed
// ... and so on ...
since you said that Scene_TV might take some time to update?
Yes, you are right
I replied too quickly.
The important bit is the delay between the command received and item being updated. Did you understant that and does it make sense.
It’s important because it can cause unpredictable behaviour (As in your case) and therefore you need to choose carefully what trigger to choose to use for your rules and learn about the implicit variables:
Thanks @vzorglub for the clarification! I think I do understand; I see the “implicit” as a the “variable” that is passed on to the rule being called (and then start executing), while in a parallel process (asynchronous to the rule execution) the item is updated. Since this is asynchronous, the item update can “fall behind” and the two therefore won’t be identical at the time when the check happens within the rule execution…
