Hi everyone.
I have a nest thermostat and some xiaomi door sensors. Ihave made a rule when one of the windows open, turn the thermostat to off. the rule is below and is working.
rule "Windows Opened"
Item LeftWindow_OpenStatus changed from CLOSED to OPEN or
Item RightWindow_OpenStatus changed from CLOSED to OPEN
LivingRoomThermostat_Mode.sendCommand("OFF")
How can i enable the rule only on specific months of year (say from october to April)
Thank you in advance
Harry’s is the easiest and most expedient solution. If you have other Rules that need to know the current month/season, you can consider adapting Design Pattern: Simple State Machine (e.g. Time Of Day) to calculate seasonal periods instead of or in addition to times of day.
