i’m with OH2.3 build1225 and suffering a rule that does not exactly what i want…
I have an MQTT publisher that sends a string with information about the person opening the front door…
via MQTT it seems that an update results in a “change” as the event log shows the following log:
2018-03-11 11:21:23.950 [vent.ItemStateChangedEvent] - LockLog changed from Outside locked. to Evi fprint2
2018-03-11 15:35:48.131 [vent.ItemStateChangedEvent] - LockLog changed from Evi fprint2 to Outside locked.
2018-03-11 16:45:28.084 [vent.ItemStateChangedEvent] - LockLog changed from Outside locked. to NJ RFID
2018-03-11 16:45:34.312 [vent.ItemStateChangedEvent] - LockLog changed from NJ RFID to Outside locked.
The rule looks as follows:
rule "SmartLOCK - Timestamp"
Item LockLog received command
postUpdate(MyLockStamp, new DateTimeType())
if ((LockLog.state=="Evi RFID") || (LockLog.state=="Evi fprint2")) { playSound("evihome2.mp3") }
if ((LockLog.state=="Frog RFID") || (LockLog.state=="NJ RFID") || (LockLog.state=="NJ fprint")) { playSound("njhome2.mp3") }
I’ve tried received command/received update…but the rule only shoots in case i send a http command directly via browser:
http://192.168.1.11:8080/classicui/CMD?LockLog=Evi fprint2
Any idea why it does not work with MQTT? the result is that depending on who comes home a different tone is played in the living room.
Cheers, Norbert
