This is a rule I use to help me to not forget to plug in my cars engine block heater in the evening.
The engine block heater draws about 500W and I also have a fan heater inside the car which draws about 1100W. The rule turns the outlet on for 10 seconds, checks the consumption and notifies me if things are in order or not. I use a Z-wave Aeotec Heavy Duty Smart Switch.
rule "Check engine block heater"
Time cron "0 0 21 ? * MON,TUE,WED,THU,SUN *" //Runt test at 2100 on Sunday to Thursday evenings.
if (EngineHeater.state == OFF){ //Only run test if outlet is OFF
sendCommand(EngineHeater, ON)
Thread::sleep(10000) //Wait 10 sec to let the outlet report the current consumption
if (EngineHeaterPower.state > 900){
sendNotification("xxxx.xxxxx@xxxx.com", "OK! Cable plugged in. " + EngineHeaterPower.state + " W")
if (EngineHeaterPower.state > 400 && EngineHeaterPower.state < 800){
sendNotification("xxxx.xxxxx@xxxx.com", "WARNING! Cable plugged in but not the fan heater. " + EngineHeaterPower.state + " W")
if (EngineHeaterPower.state < 399){
sendNotification("xxxx.xxxxx@xxxx.com", "WARNING! Cable NOT plugged in! " + EngineHeaterPower.state + " W")
sendCommand(EngineHeater, OFF)
