I have successfully created a rule that works for my Amazon Echo device to give the weather.
However, when I try to start a “routine” via my Amazon Echo, it does not work.
I created the following item in a echo.items file.
String EchoOffice_startRoutine "Start Routine" {channel="amazonechocontrol:echo:acct:serial:startRoutine"}
I have tried using the admin web page (WHEN/THEN) to construct the rule, as well as coding a one line script.
EchoOffice_startRoutine.sendCommand('Bedtime')
20:08:30.631 [INFO ] [openhab.event.ItemCommandEvent ] - Item ‘EchoOffice_startRoutine’ received command Bedtime
20:08:30.672 [INFO ] [openhab.event.ItemStatePredictedEvent] - Item ‘EchoOffice_startRoutine’ predicted to become Bedtime
20:08:37.193 [ERROR] [rnal.common.AbstractInvocationHandler] - An error occurred while calling method ‘ThingHandler.handleCommand()’ on ‘org.openhab.binding.amazonechocontrol.internal.handler.EchoHandler@1cfc46d’: GET url ‘https://alexa.amazon.com/api/behaviors/automations?limit=2000’ failed: null
org.openhab.binding.amazonechocontrol.internal.HttpException: GET url ‘https://alexa.amazon.com/api/behaviors/automations?limit=2000’ failed: null
I have openHAB 3.1.0 Build #2154 with the Amazon Echo Control Binding 3.1.0SNAPSHOT.
Thanks for any suggestions.
Mike
