Thanks Rich
The group definition is created trough the paper UI and I wasn’t sure if this is the best command to exact in cli/karaf the groups but here it is:
openhab> smarthome:items list |grep all_lights
KitchenLight_Switch1 (Type=SwitchItem, State=OFF, Label=Switch, Category=Switch, Groups=[all_lights])
all_lights (Type=GroupItem, BaseType=SwitchItem, Members=15, State=OFF, Label=All Lights, Category=)
Light_Kitchen_Table_Dimmer (Type=DimmerItem, State=0, Label=Dimmer, Category=Dimmer, Groups=[all_lights])
WashroomLight_Switch (Type=SwitchItem, State=OFF, Label=Switch, Category=null, Groups=[all_lights])
KitchenTableLight_Dimmer1 (Type=DimmerItem, State=0, Label=Dimmer, Category=DimmableLight, Groups=[all_lights])
Light_Corridor_Switch1 (Type=SwitchItem, State=OFF, Label=Switch, Category=null, Groups=[all_lights])
CorridorLights_Switch1 (Type=SwitchItem, State=OFF, Label=Switch, Category=Switch, Groups=[all_lights])
CorridorLights_Switch2 (Type=SwitchItem, State=OFF, Label=Switch, Category=Switch, Groups=[all_lights])
Light_Corridor_Switch2 (Type=SwitchItem, State=OFF, Label=Switch 2, Category=null, Groups=[all_lights])
Light_BathroomParents_Switch (Type=SwitchItem, State=OFF, Label=Switch, Category=null, Groups=[all_lights])
KitchenTableLight_Dimmer (Type=DimmerItem, State=0, Label=Dimmer, Category=DimmableLight, Groups=[all_lights])
zwave_device_e72dcfb3_node11_switch_binary_test (Type=SwitchItem, State=OFF, Label=light_bedroom_switch, Category=, Groups=[all_lights])
Test_Office_light_switch (Type=SwitchItem, State=OFF, Label=Switch, Category=Switch, Groups=[all_lights])
OfficeLight_Switch1 (Type=SwitchItem, State=OFF, Label=Switch, Category=Switch, Groups=[all_lights])
CellarLight_Switch1 (Type=SwitchItem, State=OFF, Label=Switch, Category=Switch, Groups=[all_lights])
Light_Kitchen_Switch (Type=SwitchItem, State=OFF, Label=Switch, Category=Switch, Groups=[all_lights])
see that couple of items are around the same purpose. Reason for this is most likely that I have tried out different configurations, but also default naming conventions by paper UI (which I think changed in the past) and also not clean handling of removing paper UI generated Items. I will try to clean up via cli.
The rule is a bit long, but it is getting triggered and clearly creates an output. Further as you can see i have next to the group of fibaro z-wave devices also one AVR which is also receiving an update from the rule (see rule definition) and that one works without problem. In my view that fully supports what you wrote: the binding might be a problem.
import java.util.ArrayList
import java.util.LinkedList
import java.util.Map
import java.util.regex.Pattern
import org.eclipse.smarthome.core.library.items.SwitchItem
import org.eclipse.smarthome.model.script.actions.Timer
import org.eclipse.xtext.xbase.lib.Functions
import org.eclipse.xtext.xbase.lib.Pair
import org.eclipse.xtext.xbase.lib.Procedures
import org.joda.time.DateTime
* ======================================= Tap Pattern Detection ======================================
* Ver. 1.000000000
* Author: Victor Bai
* Date: Mar 17, 2017
* Description: Function to detect switch's tapping pattern: double-tap, triple pattern, customized pattern, etc.
* Data structure to hold Tap pattern states (don't edit this, or care about it):
* {SWITCH -> [
* [{'ON' => '2017-03-12 12:30:10:125'}, {'ON' => '2017-03-12 12:30:11:125'}], // States Queue: LinkedList<Pair<String, DateTime>>
* [Pattern, Pattern, Pattern] // Holder for Pattern Strings' RegEx compilation: ArrayList<Pattern>
* [2, 0, 1], // Match results. ArrayList<Integer>. Same order as the input pattern. 0: no match; 1: partial match; 2: comple
te match
* Timer // Timer
val Map<SwitchItem, LinkedList<?>> tapStates = newHashMap
* Function detectUpdatePatterns.apply(SwitchItem, tapStates, patternConfig)
* Input Arguments:
* SwitchItem: Switch triggering the tap pattern(s)
* tapStates: rule scope predefined variable
* patternConfig: ArrayList<Pair<SwitchItem, String>> pattern definition. e.g. newArrayList(V_Office_DoubleTap->'ON,ON', V_Office_TripleTap->'ON,ON,-,ON')
* "SwitchItem" here is the virtual/proxy item you want to switch ON whenever associated pattern is detected
* "String" representing pattern composed of ',' delimited states. Possible state values are:
* "ON": state of ON
* "OFF": state of OFF
* "-": Represent a "skipping" of a tapping. you have to time it right. if it's longer than LONG_SPAN, previous tapping will be discarded
* "#": Represent any DimmerSwitch state in Positive percentage
* "0": Represent any DimmerSwitch's OFF state
* return:
* ArrayList<Integer>: list of int value indicating matching result: 0: no match; 1: partial match; 2: complete match
val Functions.Function3<
SwitchItem, // Switch triggering tapping
Map<SwitchItem, LinkedList<?>>, // Global caching variable
ArrayList<Pair<SwitchItem, String>>, // Pattern Configuration
ArrayList<Integer> // return list of int value indicating matching result.
> detectUpdatePatterns = [
SwitchItem light,
Map<SwitchItem, LinkedList<?>> tapStates,
ArrayList<Pair<SwitchItem, String>> patternConfig |
// Pre-configured time span between tapping
val SHORT_SPAN = 600 // 800ms, sequence of key pressing must happened within this time frame
val LONG_SPAN = 2*SHORT_SPAN // If time between tapping extend beyond this time, previous tapping will be ignored
// initialize
if (tapStates.get(light) == null)
tapStates.put(light, newLinkedList)
val switchState = tapStates.get(light) as LinkedList<Object>
if (switchState.size == 0) {
switchState.add(newLinkedList) // States queue
switchState.add(newArrayList) // RegEx Pattern list
switchState.add(newArrayList) // Match results
for (i : 0..<patternConfig.size)
(switchState.get(2) as ArrayList<Integer>).add(-1)
switchState.add(null) // timer
// generate patternString
// var String[] patternStrings = newArrayList
for (var i = 0; i < patternConfig.size; i++) {
var pattern = Pattern.compile('^' + patternConfig.get(i).value.replaceAll('\\s', '').replaceAll('#', '[1-9]\\d*'))
(switchState.get(1) as ArrayList<Pattern>).add(pattern)
logInfo(light.name, "Pattern[{}]: '{}' => '{}'", i, patternConfig.get(i).value, pattern)
logInfo(light.name, "detectUpdatePatterns initialized.")
val stateQueue = switchState.get(0) as LinkedList<Pair<String, DateTime>>
val patterns = switchState.get(1) as ArrayList<Pattern>
val matchResult = switchState.get(2) as ArrayList<Integer>
var tapTimer = switchState.get(3) as Timer
var eventTime = new DateTime
// pushout the old state from the queue
if (stateQueue.size > 0 && eventTime.isAfter(stateQueue.last.value.plusMillis(LONG_SPAN))) {
//logInfo(light.name, "Pushout the old state from the queue.")
stateQueue.clear
stateQueue.add(light.state.toString -> eventTime)
//logInfo(light.name, "stateQueue.size = {}", stateQueue.size)
//compose comparing string from existing queue
var queueString = ""
var DateTime last = null
for (var i = 0; i < stateQueue.length; i++) {
var state = stateQueue.get(i)
var stateTime = state.value
if (last != null && stateTime.isAfter(last.plusMillis(SHORT_SPAN))) {
queueString += ",-"
if (i > 0) queueString += ","
queueString += state.key
last = state.value
//logInfo(light.name, "queueString = {}", queueString)
// matching against patterns
var partialMatch = -1
var completeMatch = -1
for (i: 0..< patterns.size) {
//logInfo(light.name, "Pattern {} = '{}'", light.name, patterns.get(i).toString)
var matcher = patterns.get(i).matcher(queueString)
if (matcher.matches) {
completeMatch = i
matchResult.set(i, 2)
else if (matcher.hitEnd) {
// Partial match found
matchResult.set(i, 1)
partialMatch = i
else
matchResult.set(i, 0)
//logInfo(light.name, "matchResult[{}] = {}", i, matchResult.get(i))
val comp = completeMatch
if (completeMatch > -1) {
logInfo(light.name, "Complete match found for pattern: {}.", patternConfig.get(comp).value)
tapTimer?.cancel
tapTimer = null
if (partialMatch > -1) {
logInfo(light.name, "Partial match found for pattern: {}", patternConfig.get(partialMatch).value)
if (patternConfig.get(comp).key != null) {
// schedule timer for matched pattern
logInfo(light.name, "Delaying triggering for complete matched pattern: {}", patternConfig.get(comp).value)
tapTimer?.cancel
tapTimer = createTimer(now.plusMillis(LONG_SPAN))[|
stateQueue.clear
logInfo(light.name, "Fire scheduled pattern '{}' event to Switch({})", patternConfig.get(comp).value, patternConfig.get(comp).key.name)
patternConfig.get(comp).key.sendCommand(ON)
switchState.set(3, tapTimer)
else {
// No switch to receive the complete match event while partial match exist
// Do nothing, up to caller to decide the action path based on matchResult
else {
stateQueue.clear
else if (partialMatch > -1) {
// Partial match is in progress, we should stop previous delayed complete match
tapTimer?.cancel
return matchResult
rule "Corridor Double Tap"
Item CorridorLights_Switch1 received update
var matchResult = detectUpdatePatterns.apply(CorridorLights_Switch1, tapStates, newArrayList(null->'ON,OFF', null->'OFF,ON'))
if (matchResult.get(0) == 2 || matchResult.get(1) == 2) {
sendCommand (all_lights, OFF)
sendCommand (avr1Z1_Power, OFF)
After moving to the most recent snapshot 2.2.0-SNAPSHOT Build #1019 the commands are being executed as they should. Would it make most sense to check what changed from 1017 to 1019 on the z-wave binding? At the same time as this happened in the past multiple times (working / not working after update) I assume it is a bit more than a simple change which either breaks a function or not.
