Hi Volker,
as far as I can see your rule is doing the trick and should work fine.
However I’m a fan of seperating behaviors and try to follow that.
Hence I’m using multiple rules to do nearly the same as you:
rule "Weihnachtszeit"
System started or
Time is midnight
val int year = now.getYear
val int dayOfYear = now.getDayOfYear
val int xmas_start = parse(year+"-12-24").getDayOfYear - parse(now.getYear+"-12-24").getDayOfWeek - 21
val int xmas_end = parse(year+"-01-06").getDayOfYear
if ((dayOfYear > xmas_start) || (dayOfYear < xmas_end))
Zeit_Weihnachtszeit.postUpdate(ON)
else
Zeit_Weihnachtszeit.postUpdate(OFF)
rule "Weihnachtsbeleuchtung ein/aus"
Item Tagesabschnitt changed to "BED" or
Item Sonne_Phase changed to "SUN_SET"
if (Zeit_Weihnachtszeit.state == ON) {
if (Tagesabschnitt.state == "BED")
Weihnachtsbeleuchtung.sendCommand(OFF)
else if (Sonne_Phase.state == "SUN_SET")
Weihnachtsbeleuchtung.sendCommand(ON)
At every restart and midnight I check if we are between 1st Advent and 6th of Jan. If yes an item is set. Unset otherwise.
Second rule switches on lights at sunset and off when we go to bed (which is actually set at 10pm).
Regards,
Christian
