Rule's action stays empty
  • Platform information:
    • Hardware:
    • Intel(R) Atom(TM) CPU D410, 2GB RAM
    • Zigbee router: QinHeng Electronics SONOFF Zigbee 3.0 USB Dongle Plus V2, firmware 6.10.3.0
    • Zigbee power switch: EAYCBM-Z-2P
    • OS: Deban 10.11
    • Java Runtime Environment: openjdk 17.0.2
    • openHAB version: 4.2.2
  • Issue of the topic:
I’m trying to create simple rule to turn zigbee switch on at specified time.
When in rule design page I choose “fixed time of the day” for “when” and click “save” message is popped asking “Do You want to leave this page without saving?”
And iIf I try to choose any action for “then” and click “save” UI either returns to rule design page without action added or jumps into arbitrary page, usually layout design or overview. In last case whole rule is lost.
Anything I’m missing?
Welcome to the forums.
These are definitely not normal behaviors. These appear to be errors with the f7 navigator which tracks the history of page use in UI, but as other users do not report these same issues this implies that there’s something about your setup that is interfering with proper UI function.
How did you install OH, manually or via packages?
Have you checked the permissions of the files in the configuration folder especially the folder $OH_CONF/userdata/jsondb?
Do you see any errors in the browser console when creating a new rule or trying to save the when configuration?
please check if you’re still logged with you admin account. Whenever I had this problem it was because I was logged out. But I have no clue why or when this happens.
Thanks. That was it.
