robjkamp
(Rob Kamp)
December 20, 2021, 11:31am
1
OH3 on Raspberry PI 4 on OpenJRE 11
I assumed that when you send the ON command to a group that is a location that has lights in them (which are a group as well) that the model would handle the lights to go on.
Well I was wrong.
The model is as follows:
And the Rule is as follows:
configuration: {}
triggers:
- id: "1"
configuration:
thingUID: astro:sun:local
event: END
channelUID: astro:sun:local:daylight#event
type: core.ChannelEventTrigger
conditions: []
actions:
- inputs: {}
configuration:
command: ON
itemName: gWoonkamer
type: core.ItemCommandAction
How do I handle this using the model?
rossko57
(Rossko57)
December 20, 2021, 2:12pm
2
robjkamp:
Well I was wrong.
Why, what happens instead?
Your events.log
will show you commands propagating through Group members.
robjkamp
(Rob Kamp)
December 20, 2021, 2:40pm
3
The log file events.log shows nothing on prapagating commands to group members.
2021-12-20 15:35:59.515 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'LocalMoon_Distance_Distance' changed from 404351.63694037613 km to 404346.2703047954 km
2021-12-20 15:35:59.515 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'LocalMoon_Azimuth' changed from 23.87448840555013 ° to 24.924028484736365 °
2021-12-20 15:35:59.516 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'LocalMoon_Position_Elevation' changed from -8.900951704308817 ° to -8.599260652266166 °
2021-12-20 15:36:00.780 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'LocalSun_Azimuth' changed from 219.40220115386754 ° to 220.4428515920921 °
2021-12-20 15:36:00.786 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'LocalSun_Position_Elevation' changed from 5.189396483084464 ° to 4.700130202065273 °
2021-12-20 15:36:00.788 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'LocalSun_ShadeLengthRatio' changed from 11.01 to 12.16
2021-12-20 15:36:00.795 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'LocalSun_DirectRadiation' changed from 0.7194589331793891 W/m² to 0.41794660392102545 W/m²
2021-12-20 15:36:00.805 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'LocalSun_DiffuseRadiation' changed from 34.41398886263369 W/m² to 31.245782565739944 W/m²
2021-12-20 15:36:00.806 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'LocalSun_TotalRadiation' changed from 35.133447795813076 W/m² to 31.663729169660968 W/m²
2021-12-20 15:36:15.314 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'iPhonevanPuck_Uptime' changed from 4652651 to 4652681
2021-12-20 15:36:15.317 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'iPhonevanPuck_LastSeen' changed from 2021-12-20T15:35:42.000+0100 to 2021-12-20T15:36:12.000+0100
2021-12-20 15:36:25.534 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'iPhonevanRob_Uptime' changed from 1319127 to 1319152
2021-12-20 15:36:25.536 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'iPhonevanRob_LastSeen' changed from 2021-12-20T15:35:53.000+0100 to 2021-12-20T15:36:18.000+0100
2021-12-20 15:36:25.537 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'iPhonevanRob_ReceivedSignalStrengthIndicator' changed from 55 to 51
2021-12-20 15:36:45.828 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'iPhonevanPuck_Uptime' changed from 4652681 to 4652708
2021-12-20 15:36:45.830 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'iPhonevanPuck_LastSeen' changed from 2021-12-20T15:36:12.000+0100 to 2021-12-20T15:36:39.000+0100
2021-12-20 15:36:45.833 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'iPhonevanRob_Uptime' changed from 1319152 to 1319179
2021-12-20 15:36:45.833 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'iPhonevanRob_LastSeen' changed from 2021-12-20T15:36:18.000+0100 to 2021-12-20T15:36:45.000+0100
2021-12-20 15:36:45.834 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'iPhonevanRob_ReceivedSignalStrengthIndicator' changed from 51 to 52
2021-12-20 15:37:16.370 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'iPhonevanPuck_Uptime' changed from 4652708 to 4652737
2021-12-20 15:37:16.372 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'iPhonevanPuck_LastSeen' changed from 2021-12-20T15:36:39.000+0100 to 2021-12-20T15:37:08.000+0100
2021-12-20 15:37:16.373 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'iPhonevanRob_Uptime' changed from 1319179 to 1319206
2021-12-20 15:37:16.373 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'iPhonevanRob_LastSeen' changed from 2021-12-20T15:36:45.000+0100 to 2021-12-20T15:37:12.000+0100
2021-12-20 15:37:36.702 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'iPhonevanPuck_Uptime' changed from 4652737 to 4652765
2021-12-20 15:37:36.704 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'iPhonevanPuck_LastSeen' changed from 2021-12-20T15:37:08.000+0100 to 2021-12-20T15:37:36.000+0100
2021-12-20 15:37:46.865 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'iPhonevanRob_Uptime' changed from 1319206 to 1319233
2021-12-20 15:37:46.868 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'iPhonevanRob_LastSeen' changed from 2021-12-20T15:37:12.000+0100 to 2021-12-20T15:37:39.000+0100
2021-12-20 15:38:07.300 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'iPhonevanPuck_Uptime' changed from 4652765 to 4652793
2021-12-20 15:38:07.303 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'iPhonevanPuck_LastSeen' changed from 2021-12-20T15:37:36.000+0100 to 2021-12-20T15:38:04.000+0100
2021-12-20 15:38:17.507 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'iPhonevanRob_Uptime' changed from 1319233 to 1319262
2021-12-20 15:38:17.508 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'iPhonevanRob_LastSeen' changed from 2021-12-20T15:37:39.000+0100 to 2021-12-20T15:38:08.000+0100
2021-12-20 15:38:17.509 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'iPhonevanRob_ReceivedSignalStrengthIndicator' changed from 52 to 51
2021-12-20 15:38:37.776 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'iPhonevanPuck_Uptime' changed from 4652793 to 4652821
2021-12-20 15:38:37.781 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'iPhonevanPuck_LastSeen' changed from 2021-12-20T15:38:04.000+0100 to 2021-12-20T15:38:32.000+0100
2021-12-20 15:38:37.782 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'iPhonevanRob_Uptime' changed from 1319262 to 1319288
2021-12-20 15:38:37.783 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'iPhonevanRob_LastSeen' changed from 2021-12-20T15:38:08.000+0100 to 2021-12-20T15:38:34.000+0100
2021-12-20 15:39:08.261 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'iPhonevanPuck_Uptime' changed from 4652821 to 4652849
2021-12-20 15:39:08.263 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'iPhonevanPuck_LastSeen' changed from 2021-12-20T15:38:32.000+0100 to 2021-12-20T15:39:00.000+0100
2021-12-20 15:39:08.264 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'iPhonevanRob_Uptime' changed from 1319288 to 1319318
2021-12-20 15:39:08.264 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'iPhonevanRob_LastSeen' changed from 2021-12-20T15:38:34.000+0100 to 2021-12-20T15:39:04.000+0100
2021-12-20 15:39:28.587 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'iPhonevanPuck_Uptime' changed from 4652849 to 4652876
2021-12-20 15:39:28.589 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'iPhonevanPuck_LastSeen' changed from 2021-12-20T15:39:00.000+0100 to 2021-12-20T15:39:27.000+0100
2021-12-20 15:39:38.718 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'iPhonevanRob_Uptime' changed from 1319318 to 1319343
2021-12-20 15:39:38.720 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'iPhonevanRob_LastSeen' changed from 2021-12-20T15:39:04.000+0100 to 2021-12-20T15:39:29.000+0100
rossko57
(Rossko57)
December 20, 2021, 3:32pm
4
Okay, nothing happened. Do you actually have an Item named gWoonkamer
? Although you really want to look in your events.log at the astro:sun:local:daylight
event time.
robjkamp
(Rob Kamp)
December 20, 2021, 3:55pm
5
Nothing happens when I run the rule manually. Do I have to wait for the actual trigger or is it ok to run the rule manually?
robjkamp
(Rob Kamp)
December 20, 2021, 4:01pm
6
Nothing again on the astro:sun:local:daylight#event triggered END
openhabian@openhab:/var/log/openhab $ grep "2021-12-20 16:23" openhab.log events.log
events.log:2021-12-20 16:23:00.003 [INFO ] [openhab.event.ChannelTriggeredEvent ] - astro:sun:local:daylight#event triggered END
events.log:2021-12-20 16:23:00.004 [INFO ] [openhab.event.ChannelTriggeredEvent ] - astro:sun:local:set#event triggered START
events.log:2021-12-20 16:23:00.005 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'LocalSun_SunPhaseName' changed from DAYLIGHT to SUN_SET
events.log:2021-12-20 16:23:00.676 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'iPhonevanPuck_Uptime' changed from 4655450 to 4655482
events.log:2021-12-20 16:23:00.678 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'iPhonevanPuck_LastSeen' changed from 2021-12-20T16:22:21.000+0100 to 2021-12-20T16:22:53.000+0100
events.log:2021-12-20 16:23:00.680 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'iPhonevanRob_Uptime' changed from 1321918 to 1321950
events.log:2021-12-20 16:23:00.681 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'iPhonevanRob_LastSeen' changed from 2021-12-20T16:22:24.000+0100 to 2021-12-20T16:22:56.000+0100
events.log:2021-12-20 16:23:01.955 [INFO ] [openhab.event.ItemUpdatedEvent ] - Item 'gWiFi' has been updated.
events.log:2021-12-20 16:23:10.874 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'iPhonevanPuck_Uptime' changed from 4655482 to 4655493
events.log:2021-12-20 16:23:10.876 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'iPhonevanPuck_LastSeen' changed from 2021-12-20T16:22:53.000+0100 to 2021-12-20T16:23:04.000+0100
events.log:2021-12-20 16:23:10.880 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'iPhonevanRob_Uptime' changed from 1321950 to 1321961
events.log:2021-12-20 16:23:10.882 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'iPhonevanRob_LastSeen' changed from 2021-12-20T16:22:56.000+0100 to 2021-12-20T16:23:07.000+0100
events.log:2021-12-20 16:23:21.142 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'iPhonevanPuck_Uptime' changed from 4655493 to 4655504
events.log:2021-12-20 16:23:21.143 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'iPhonevanPuck_LastSeen' changed from 2021-12-20T16:23:04.000+0100 to 2021-12-20T16:23:15.000+0100
events.log:2021-12-20 16:23:21.144 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'iPhonevanRob_Uptime' changed from 1321961 to 1321972
events.log:2021-12-20 16:23:21.144 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'iPhonevanRob_LastSeen' changed from 2021-12-20T16:23:07.000+0100 to 2021-12-20T16:23:18.000+0100
events.log:2021-12-20 16:23:26.304 [INFO ] [openhab.event.ItemUpdatedEvent ] - Item 'gWoonkamer' has been updated.
events.log:2021-12-20 16:23:31.337 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'iPhonevanPuck_Uptime' changed from 4655504 to 4655514
events.log:2021-12-20 16:23:31.339 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'iPhonevanPuck_LastSeen' changed from 2021-12-20T16:23:15.000+0100 to 2021-12-20T16:23:25.000+0100
events.log:2021-12-20 16:23:31.342 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'iPhonevanRob_Uptime' changed from 1321972 to 1321983
events.log:2021-12-20 16:23:31.344 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'iPhonevanRob_LastSeen' changed from 2021-12-20T16:23:18.000+0100 to 2021-12-20T16:23:29.000+0100
events.log:2021-12-20 16:23:41.549 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'iPhonevanPuck_Uptime' changed from 4655514 to 4655525
events.log:2021-12-20 16:23:41.550 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'iPhonevanPuck_LastSeen' changed from 2021-12-20T16:23:25.000+0100 to 2021-12-20T16:23:36.000+0100
events.log:2021-12-20 16:23:41.552 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'iPhonevanRob_Uptime' changed from 1321983 to 1321993
events.log:2021-12-20 16:23:41.553 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'iPhonevanRob_LastSeen' changed from 2021-12-20T16:23:29.000+0100 to 2021-12-20T16:23:39.000+0100
events.log:2021-12-20 16:23:43.750 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_FramesAcknowledged' changed from 7108 to 7109
events.log:2021-12-20 16:23:43.754 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_StartFrames' changed from 21169 to 21170
events.log:2021-12-20 16:23:43.908 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_StartFrames' changed from 21170 to 21171
events.log:2021-12-20 16:23:44.046 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_StartFrames' changed from 21171 to 21172
events.log:2021-12-20 16:23:44.063 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_FramesAcknowledged' changed from 7109 to 7110
events.log:2021-12-20 16:23:44.067 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_StartFrames' changed from 21172 to 21173
events.log:2021-12-20 16:23:44.364 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_StartFrames' changed from 21173 to 21174
events.log:2021-12-20 16:23:44.493 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_StartFrames' changed from 21174 to 21175
events.log:2021-12-20 16:23:44.508 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_FramesAcknowledged' changed from 7110 to 7111
events.log:2021-12-20 16:23:44.512 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_StartFrames' changed from 21175 to 21176
events.log:2021-12-20 16:23:44.787 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_StartFrames' changed from 21176 to 21177
events.log:2021-12-20 16:23:44.948 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_StartFrames' changed from 21177 to 21178
events.log:2021-12-20 16:23:44.965 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_FramesAcknowledged' changed from 7111 to 7112
events.log:2021-12-20 16:23:44.969 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_StartFrames' changed from 21178 to 21179
events.log:2021-12-20 16:23:45.231 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_StartFrames' changed from 21179 to 21180
events.log:2021-12-20 16:23:45.366 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_StartFrames' changed from 21180 to 21181
events.log:2021-12-20 16:23:45.382 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_FramesAcknowledged' changed from 7112 to 7113
events.log:2021-12-20 16:23:45.386 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_StartFrames' changed from 21181 to 21182
events.log:2021-12-20 16:23:45.686 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_StartFrames' changed from 21182 to 21183
events.log:2021-12-20 16:23:45.813 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_StartFrames' changed from 21183 to 21184
events.log:2021-12-20 16:23:45.828 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_FramesAcknowledged' changed from 7113 to 7114
events.log:2021-12-20 16:23:45.831 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_StartFrames' changed from 21184 to 21185
events.log:2021-12-20 16:23:46.108 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_StartFrames' changed from 21185 to 21186
events.log:2021-12-20 16:23:46.268 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_StartFrames' changed from 21186 to 21187
events.log:2021-12-20 16:23:46.284 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_FramesAcknowledged' changed from 7114 to 7115
events.log:2021-12-20 16:23:46.289 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_StartFrames' changed from 21187 to 21188
events.log:2021-12-20 16:23:46.551 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_StartFrames' changed from 21188 to 21189
events.log:2021-12-20 16:23:46.686 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_StartFrames' changed from 21189 to 21190
events.log:2021-12-20 16:23:46.706 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_FramesAcknowledged' changed from 7115 to 7116
events.log:2021-12-20 16:23:46.710 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_StartFrames' changed from 21190 to 21191
events.log:2021-12-20 16:23:47.008 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_StartFrames' changed from 21191 to 21192
events.log:2021-12-20 16:23:47.133 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_StartFrames' changed from 21192 to 21193
events.log:2021-12-20 16:23:47.148 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_FramesAcknowledged' changed from 7116 to 7117
events.log:2021-12-20 16:23:47.152 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_StartFrames' changed from 21193 to 21194
events.log:2021-12-20 16:23:47.428 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_StartFrames' changed from 21194 to 21195
events.log:2021-12-20 16:23:47.592 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_StartFrames' changed from 21195 to 21196
events.log:2021-12-20 16:23:47.607 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_FramesAcknowledged' changed from 7117 to 7118
events.log:2021-12-20 16:23:47.611 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_StartFrames' changed from 21196 to 21197
events.log:2021-12-20 16:23:47.871 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_StartFrames' changed from 21197 to 21198
events.log:2021-12-20 16:23:48.007 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_StartFrames' changed from 21198 to 21199
events.log:2021-12-20 16:23:48.025 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_FramesAcknowledged' changed from 7118 to 7119
events.log:2021-12-20 16:23:48.030 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_StartFrames' changed from 21199 to 21200
events.log:2021-12-20 16:23:48.328 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_StartFrames' changed from 21200 to 21201
events.log:2021-12-20 16:23:48.453 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_StartFrames' changed from 21201 to 21202
events.log:2021-12-20 16:23:48.468 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_FramesAcknowledged' changed from 7119 to 7120
events.log:2021-12-20 16:23:48.472 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_StartFrames' changed from 21202 to 21203
events.log:2021-12-20 16:23:48.758 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_StartFrames' changed from 21203 to 21204
events.log:2021-12-20 16:23:48.922 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_StartFrames' changed from 21204 to 21205
events.log:2021-12-20 16:23:51.695 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'iPhonevanPuck_Uptime' changed from 4655525 to 4655536
events.log:2021-12-20 16:23:51.696 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'iPhonevanPuck_LastSeen' changed from 2021-12-20T16:23:36.000+0100 to 2021-12-20T16:23:47.000+0100
events.log:2021-12-20 16:23:51.702 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'iPhonevanPuck_ReceivedSignalStrengthIndicator' changed from 34 to 33
events.log:2021-12-20 16:23:51.703 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'iPhonevanRob_Uptime' changed from 1321993 to 1322004
events.log:2021-12-20 16:23:51.704 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'iPhonevanRob_LastSeen' changed from 2021-12-20T16:23:39.000+0100 to 2021-12-20T16:23:50.000+0100
rossko57
(Rossko57)
December 20, 2021, 4:11pm
7
To repeat
Is it a Group? Does it have a sub-type?
robjkamp
(Rob Kamp)
December 20, 2021, 7:42pm
8
It had no subtype so I changed it now to dimmer. It does work now, but not in the way expected.
I now have to split the room into lights and other stuff. This makes the model bigger than necessary.
Anyways that’s a design decision which I cannot change.
rossko57
(Rossko57)
December 20, 2021, 8:05pm
9
Well, the groupings in the model reflect mostly just physical location. You can make other groupings - by technical type, for example all lights - by using Groups outside of the model. You’re not obliged to use the model at all, and it certainly will not cater for all possibilities.
