- Platform information: RPi 3B, openHABian, openHAB 2.5.10, HABpanel
I have the following setup
- Various bindings incl. Z-Wave, MagentaTV, Shelly, Sony, DreamScreen
- more than 200 Things/Items
- Most things/items are defined via PaperUI, only some textual config
- Standard Rules (DSL)
Config
- various things/item mappings are define to control my multimedia stuff
- HABpanel defines the UI and process access to singular items or trigger scenes/rues
- The rule includes a series of actions (switch on TV and receiver, select HDMI, set Ambilight…)
So just plain scenario: HABpanel triggers an items, a rule gets triggered, rule is executed
Problem
- I had a setup based on OH 2.5.4, whiich worked pretty well. In some rare cases I saw a delay of 15s before the sceen got executed
- After upgrading to 2.5.6 I noticed that delay has increaed to 15-30s, but number of issues was still acceptable
- with 2.5.7 it got worth and 2.5.10 even doesn’t fixed it. Now I see most times a 15-60sec delay and only sometimes the rule is triggered straight
Example:
- command is triggered at 21:19:52
- rule execution starts at 21:19:54
= 12secs of “nothing” before the rule executes
2020-11-23 21:19:42.530 [ome.event.ItemCommandEvent] - Item 'AVR_Program' received command ENTERTAIN
2020-11-23 21:19:42.539 [vent.ItemStateChangedEvent] - AVR_Program changed from OFF to ENTERTAIN
2020-11-23 21:19:54.604 [INFO ] [g.eclipse.smarthome.model.script.AVR] - Activate Program: ENTERTAIN
2020-11-23 21:19:54.606 [INFO ] [g.eclipse.smarthome.model.script.AVR] - switch AVR ON
2020-11-23 21:19:54.612 [ome.event.ItemCommandEvent] - Item 'DenonPower' received command ON
2020-11-23 21:19:54.620 [INFO ] [g.eclipse.smarthome.model.script.AVR] - switch to Entertain
2020-11-23 21:19:54.649 [ome.event.ItemCommandEvent] - Item 'DreamScreenTV_Power' received command ON
2020-11-23 21:19:54.649 [INFO ] [g.eclipse.smarthome.model.script.AVR] - done
2020-11-23 21:19:54.668 [ome.event.ItemCommandEvent] - Item 'DreamScreenTV_InputSource' received command 1
2020-11-23 21:19:54.685 [ome.event.ItemCommandEvent] - Item 'TVWohnzimmer_MainSource' received command extInput:hdmi?port=3
2020-11-23 21:19:54.701 [ome.event.ItemCommandEvent] - Item 'DreamScreenTV_Mode' received command 0
2020-11-23 21:19:54.707 [ome.event.ItemCommandEvent] - Item 'DenonInput' received command SAT/CBL
2020-11-23 21:19:54.712 [ome.event.ItemCommandEvent] - Item 'DenonVolume' received command 55.0
2020-11-23 21:19:54.714 [nt.ItemStatePredictedEvent] - DreamScreenTV_Power predicted to become ON
2020-11-23 21:19:54.725 [ome.event.ItemCommandEvent] - Item 'DenonCommand' received command MSSTANDARD
2020-11-23 21:19:54.735 [ome.event.ItemCommandEvent] - Item 'RadioKitchen_Power' received command OFF
2020-11-23 21:19:54.748 [ome.event.ItemCommandEvent] - Item 'Plug_WonZ_TVL' received command ON
2020-11-23 21:19:54.760 [ome.event.ItemCommandEvent] - Item 'TVWohnzimmer_Power' received command ON
2020-11-23 21:19:54.763 [nt.ItemStatePredictedEvent] - DreamScreenTV_InputSource predicted to become 1
2020-11-23 21:19:54.770 [nt.ItemStatePredictedEvent] - TVWohnzimmer_MainSource predicted to become extInput:hdmi?port=3
2020-11-23 21:19:54.778 [nt.ItemStatePredictedEvent] - DreamScreenTV_Mode predicted to become 0
2020-11-23 21:19:54.789 [vent.ItemStateChangedEvent] - DreamScreenTV_Power changed from OFF to ON
2020-11-23 21:19:54.792 [nt.ItemStatePredictedEvent] - RadioKitchen_Power predicted to become OFF
2020-11-23 21:19:54.798 [nt.ItemStatePredictedEvent] - Plug_WonZ_TVL predicted to become ON
2020-11-23 21:19:54.806 [nt.ItemStatePredictedEvent] - TVWohnzimmer_Power predicted to become ON
2020-11-23 21:19:54.812 [vent.ItemStateChangedEvent] - Plug_WonZ_TVL changed from OFF to ON
2020-11-23 21:20:00.016 [vent.ItemStateChangedEvent] - PondPump2_PumpTotalWatts changed from 4.893 kWh to 4.894 kWh
2020-11-23 21:20:00.026 [INFO ] [lipse.smarthome.model.script.DayTime] - nNow=2120,nSunset=0,nSunrise=0isNight=false,isWeekend=false
This is the beginning of the rule:
val String source_tv = "tv:dvbs"
val String source_hdmi1 = "extInput:hdmi?port=1"
val String source_hdmi2 = "extInput:hdmi?port=2"
val String source_hdmi3 = "extInput:hdmi?port=3"
val String source_hdmi4 = "extInput:hdmi?port=4"
// AV Reveiver Programs
rule "AVR Program"
Item AVR_Program received command
logInfo("AVR", "Activate Program: " + AVR_Program.state.toString())
if (receivedCommand.toString() == "OFF") {
logInfo("AVR", " switch TV+AVR OFF")
sendCommand(DreamScreenTV_Power, OFF)
sendCommand(DenonPower, OFF)
if (EntertainTV_Power.state != OFF) {
sendCommand(EntertainTV_Power, OFF)
sendCommand(TVWohnzimmer_Power, OFF)
//callScript("tv_off")
gAVR_Modes?.members.forEach([sw|
logInfo("AVR-OFF", " set " + sw.name + " to OFF (old state=" + sw.state.toString() + ")")
sw.postUpdate(OFF)
else {
logInfo("AVR", " switch AVR ON")
sendCommand(DenonPower, ON)
if ((receivedCommand.toString() == "TV") ||
(receivedCommand.toString() == "ON"))
//sendCommand(AmazonEchoDot_Speak, "Fernsehn wird eingeschaltet")
sendCommand(TVWohnzimmer_Power, ON)
sendCommand(DenonInput, "TV")
sendCommand(RadioKitchen_Power, OFF)
sendCommand(TVWohnzimmer_MainSource, source_tv)
sendCommand(TVWohnzimmer_VolumeSpeaker, 60.0)
sendCommand(DenonCommand, "MSMCH STEREO")
sendCommand(DenonVolume, 55.0)
postUpdate(AVR_TV, ON)
Looking to openhab.log I see
- The command is send when I “click” the action in HABpanel
- then nothing happens for about 10-30sec
- then the rule gets executed and performs as expected
I already checked
- there are no sleeps or executeCommandLins, I don’t use any reentrant lock prevention (no this in this scenario)
- no errors or exceptions in the log, which could explain the behaviour
- I’m not aware of any 30sec timeouts (tried grep 30000/15000/10000)
It just blocks between item receiving the command and execution of the rule
Question: How could I debug the event bus or rule engine to get some more details? You know: If there is a wife and the automation is not working… ![]()
