I have two sets of similar rules. When I first set them up, they didn’t work (mostly typical typos and such). But when I got them working, I found that they would stop or stop working every time I did something with the files.
For instance, I would modify one file, and the other set of rules would stop working.
One set of rules turns a frog night light on or off in response to a button press (B3) on an X10 controller (through an Insteon PLM). The other set does the same thing but in response to B4.
frog_nightlight_b3.rules
rule "turn on frog"
// Item x10SwitchB3 received command ON
Item x10SwitchB3 changed from OFF to ON
master_frog_nightlight.sendCommand(ON)
logInfo("rules", "frogb3 on")
rule "turn off frog"
// Item x10SwitchB3 receieved command OFF
Item x10SwitchB3 changed from ON to OFF
master_frog_nightlight.sendCommand(OFF)
logInfo("rules", "frogb3 off")
frog_nightlight_b4.rules
rule "turn on frog"
// Item x10SwitchB4 received command ON
Item x10SwitchB4 changed from OFF to ON
logInfo("rules", "frogb4 on")
// Item x10SwitchB4 receieved command OFF
Item x10SwitchB4 changed from ON to OFF
logInfo("rules", "frogb4 off")
From my log:
2017-10-26 17:51:13.618 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'frog_nightlight_b3.rules'
2017-10-26 17:51:13.830 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'frog_nightlight_b3.rules'
2017-10-26 17:51:17.490 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'frog_nightlight_b4.rules'
2017-10-26 17:51:17.721 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'frog_nightlight_b4.rules'
2017-10-26 17:51:17.918 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'frog_nightlight_b4.rules'
2017-10-26 17:51:39.158 [INFO ] [onplm.internal.device.MessageHandler] - X10OnHandler: set X10 device B.3 to ON
2017-10-26 17:51:41.286 [INFO ] [onplm.internal.device.MessageHandler] - X10OffHandler: set X10 device B.3 to OFF
2017-10-26 17:51:43.191 [INFO ] [onplm.internal.device.MessageHandler] - X10OnHandler: set X10 device B.3 to ON
2017-10-26 17:51:45.093 [INFO ] [onplm.internal.device.MessageHandler] - X10OffHandler: set X10 device B.3 to OFF
2017-10-26 17:51:46.725 [INFO ] [onplm.internal.device.MessageHandler] - X10OnHandler: set X10 device B.4 to ON
2017-10-26 17:51:48.437 [INFO ] [onplm.internal.device.MessageHandler] - X10OffHandler: set X10 device B.4 to OFF
2017-10-26 17:51:48.618 [INFO ] [eclipse.smarthome.model.script.rules] - frogb4 off
2017-10-26 17:51:50.260 [INFO ] [onplm.internal.device.MessageHandler] - X10OnHandler: set X10 device B.4 to ON
2017-10-26 17:51:50.270 [INFO ] [eclipse.smarthome.model.script.rules] - frogb4 on
2017-10-26 17:51:52.292 [INFO ] [onplm.internal.device.MessageHandler] - X10OffHandler: set X10 device B.4 to OFF
2017-10-26 17:51:52.306 [INFO ] [eclipse.smarthome.model.script.rules] - frogb4 off
2017-10-26 17:51:53.844 [INFO ] [onplm.internal.device.MessageHandler] - X10OnHandler: set X10 device B.4 to ON
2017-10-26 17:51:53.854 [INFO ] [eclipse.smarthome.model.script.rules] - frogb4 on
2017-10-26 17:51:55.540 [INFO ] [onplm.internal.device.MessageHandler] - X10OffHandler: set X10 device B.4 to OFF
2017-10-26 17:51:55.549 [INFO ] [eclipse.smarthome.model.script.rules] - frogb4 off
2017-10-26 17:51:57.267 [INFO ] [onplm.internal.device.MessageHandler] - X10OnHandler: set X10 device B.3 to ON
2017-10-26 17:51:59.459 [INFO ] [onplm.internal.device.MessageHandler] - X10OffHandler: set X10 device B.3 to OFF
2017-10-26 17:52:01.059 [INFO ] [onplm.internal.device.MessageHandler] - X10OnHandler: set X10 device B.3 to ON
2017-10-26 17:52:02.850 [INFO ] [onplm.internal.device.MessageHandler] - X10OffHandler: set X10 device B.3 to OFF
2017-10-26 17:52:04.275 [INFO ] [onplm.internal.device.MessageHandler] - X10OnHandler: set X10 device B.3 to ON
2017-10-26 17:52:05.618 [INFO ] [onplm.internal.device.MessageHandler] - X10OnHandler: set X10 device B.4 to ON
2017-10-26 17:52:05.630 [INFO ] [eclipse.smarthome.model.script.rules] - frogb4 on
2017-10-26 17:52:06.979 [INFO ] [onplm.internal.device.MessageHandler] - X10OffHandler: set X10 device B.4 to OFF
2017-10-26 17:52:06.989 [INFO ] [eclipse.smarthome.model.script.rules] - frogb4 off
2017-10-26 17:52:08.129 [INFO ] [onplm.internal.device.MessageHandler] - X10OnHandler: set X10 device B.4 to ON
2017-10-26 17:52:08.137 [INFO ] [eclipse.smarthome.model.script.rules] - frogb4 on
2017-10-26 17:52:09.361 [INFO ] [onplm.internal.device.MessageHandler] - X10OffHandler: set X10 device B.4 to OFF
2017-10-26 17:52:09.370 [INFO ] [eclipse.smarthome.model.script.rules] - frogb4 off
As you can see from the debugging log, even though both sets of rules are there and should work, only (right now) the B4 rules work.
Something tells me this is something simple, but if it is, I’m not seeing it. I don’t think it’s the fact that both sets of rules are controlling the same item, because there was a point yesterday when both sets worked at the same time.
Any suggestions would be greatly appreciated.
Paul
