- Platform information:
- Hardware: Raspberry Pi 5
- Java Runtime Environment: 17.0.14 (undefined)
- openHAB version: 4.3.4
I have 19 rules running in Openhab and at the moment I have the problem that sometimes these rules are not executed… Where can I have a look why the rules are not executed?
For example I have a Aquara button.
The press of the button is recognized all the time: buttonevent triggered 1002
But: my script is sometimes executed… sometimes its not…
The only warnings I get in the logs are:
WARN org.openhab.binding.ipcamera.internal.handler.IpCameraHandler Binding has not been supplied with a FFmpeg Input URL, so some features will not work.
09:38:41.666 ERROR com.github.hypfvieh.DbusHelper Critical error while reading DBUS response (maybe no bluetoothd daemon running?)
Why my IpCamera is not found: its off at the moment… and bluetooth is not used - so I see no problem here.
I have some rules that are goint through loops some hours.
For example:
When the voltage sensor of my wall plug changes and its over a amount of Amps: I go through a cycle of loops in the program and wait till for some time its under a certain amount of power.
So I can say: shut off the power of the wall plug and tell me over instagram that my cloth washing mashine is ready.
Or: when the 3D printer is ready: Wait till the bed is under 40°C and then tell me that the printer is ready.
While this time the rules are in a loop.
Is this a problem?
Here is what I want to execute (only a example):
configuration: {}
triggers:
- id: "1"
configuration:
itemName: Aqara_Taster_1_Schaltflache
conditions: []
actions:
- inputs: {}
configuration:
blockSource: <xml
xmlns="https://developers.google.com/blockly/xml"><variables><variable
id="n[YIloP6[oCCWH${ebRR">Button</variable></variables><block
type="variables_set" id="U;2KOux;/m|{TTqX0]/=" x="317" y="240"><field
name="VAR" id="n[YIloP6[oCCWH${ebRR">Button</field><value
name="VALUE"><block type="oh_getitem_state"
id="Z#6,A3r1M;vRn^%v(G4j"><value name="itemName"><shadow type="oh_item"
id="dMb_C@23y!yjgZ[4nPbl"><mutation itemName="MyItem"
itemLabel="MyItem"></mutation><field
name="itemName">MyItem</field></shadow><block type="oh_item"
id="d7Ns/oR?P/y_8kod[g:h"><mutation
itemName="Aqara_Taster_1_Schaltflache"
itemLabel="Schaltfläche"></mutation><field
name="itemName">Aqara_Taster_1_Schaltflache</field></block></value></block></value><next><block
type="controls_if" id="#8Q^}hZ5i#!~5qZc$dRg"><value name="IF0"><block
type="logic_compare" id="ugQJ8V29])0Bhe?icU9t"><field
name="OP">EQ</field><value name="A"><block type="variables_get"
id="=?6V@8njIX^v9Sq+:#Vr"><field name="VAR"
id="n[YIloP6[oCCWH${ebRR">Button</field></block></value><value
name="B"><block type="text" id="arAD0ly3`:p#i=uW4Wd="><field
name="TEXT">1002</field></block></value></block></value><statement
name="DO0"><block type="telegram_message"
id="lJ}Dxb6a3(co|(Dej$dg"><value name="MESSAGE"><shadow type="text"
id="admyhcqHmg%S]N;lMpU("><field name="TEXT">What's
up?</field></shadow><block type="text" id="[,0My_J@AOM({2/{,EWZ"><field
name="TEXT">Single Click</field></block></value><value
name="BOT"><shadow type="oh_thing" id="P9F`z[S2QeGnsphA9}-c"><field
name="thingUid">MyThing</field></shadow><block type="oh_thing"
id="r)Oe|aY[6TLZvG-QtT#f"><field
name="thingUid">telegram:telegramBot:e87958c821</field></block></value><next><block
type="oh_event" id="tO)AC~6(ij;nyCZ`u]Xv"><field
name="eventType">sendCommand</field><value name="value"><shadow
type="text" id="eE-p9ad2OlHpNqe|$Ypt"><field
name="TEXT">value</field></shadow><block type="text"
id="E~jn_X@*7FEU7TS($51;"><field
name="TEXT">ON</field></block></value><value name="itemName"><shadow
type="oh_item" id="qg2/Hlxu`j/Xu/|/8MY^"><mutation itemName="MyItem"
id="5If^*rlQC+?:uN`goO25"><mutation
itemName="Zigbee_Steckdose_7_Betrieb"
itemLabel="Betrieb"></mutation><field
name="itemName">Zigbee_Steckdose_7_Betrieb</field></block></value></block></next></block></statement><next><block
type="controls_if" id="d+pt|EQ3yscFhI?a/Gu."><value name="IF0"><block
type="logic_compare" id="){gP-*vQXD9wS2^ay:(A"><field
id="q!b_ZAXy5/}1WYt1kEz_"><field name="VAR"
name="B"><block type="text" id="Dlh=lnBrBJT=?BnDu$zs"><field
name="TEXT">1004</field></block></value></block></value><statement
id="_ssx_t3+k-$nKt#LQbf0"><value name="MESSAGE"><shadow type="text"
up?</field></shadow><block type="text" id="2)rglFPm]mz(j1$b7;Ee"><field
name="TEXT">Double Click</field></block></value><value
id="Wxr.SrB@8pla*gpSF9?H"><field
type="oh_event" id="u%C.ea[VMu^WP5rf5qVM"><field
id="qiF3`[Eq;%m0z@@dU%c="><field
name="TEXT">OFF</field></block></value><value name="itemName"><shadow
id="9P~v#dn*u21/2sM?ww(8"><mutation
type="controls_if" id="M!*mCf(iGI@Ywv7QzWB#"><value name="IF0"><block
type="logic_operation" id="}HBg4:tdNd``0BS=b-D)"><field
name="OP">OR</field><value name="A"><block type="logic_compare"
id=":rhg*7aI:?eWhULYbC.t"><field name="OP">EQ</field><value
name="A"><block type="variables_get" id="~9Jv)8u?Y$4t:yGZTL~("><field
name="VAR"
name="B"><block type="text" id="mB6Up3Sf,x^,z2Oz6eO!"><field
name="TEXT">1001</field></block></value></block></value><value
name="B"><block type="logic_compare" id="4WfW5eND9Ar_EoF4vJMu"><field
id="^ujCukJU+__9igs~n16d"><field name="VAR"
name="B"><block type="text" id="dB8wM$fgj2c/V+RF2Ac!"><field
name="TEXT">1003</field></block></value></block></value></block></value><statement
id="@TYcE,ee2SWmUTBQSZf4"><value name="MESSAGE"><shadow type="text"
up?</field></shadow><block type="text" id="_LAO8?;~$n8fJOM)qOjb"><field
name="TEXT">Long Click</field></block></value><value name="BOT"><shadow
id="x/c$S6o_f{vqGA/i[3jP"><field
type="oh_event" id="Ugs5Ix#H(nVqtwYd`yfS"><field
id="R@jN$5Vo8#my[B0rVz-O"><field
id="zOWPEuYB^2%}0]_q]p[T"><mutation
name="itemName">Zigbee_Steckdose_7_Betrieb</field></block></value></block></next></block></statement></block></next></block></next></block></next></block></xml>
type: application/javascript
script: >
var Button;
var things = Java.type('org.openhab.core.model.script.actions.Things');
Button = items.getItem('Aqara_Taster_1_Schaltflache').state;
if (Button == '1002') {
things.getActions('telegram', 'telegram:telegramBot:e87958c821').sendTelegram('Single Click');
items.getItem('Zigbee_Steckdose_7_Betrieb').sendCommand('ON');
if (Button == '1004') {
things.getActions('telegram', 'telegram:telegramBot:e87958c821').sendTelegram('Double Click');
items.getItem('Zigbee_Steckdose_7_Betrieb').sendCommand('OFF');
if (Button == '1001' || Button == '1003') {
things.getActions('telegram', 'telegram:telegramBot:e87958c821').sendTelegram('Long Click');
type: script.ScriptAction
