I’m trying to implement two rules which both is depending on states of the sun. I do this through Paper UI and the code below is fetch from DB using REST API. I have search the forum but not yet found an answer to my problems.
Rule 1:
This rule shall switch on a lamp in the ground floor when I stop watching TV on first floor. My TV also control my receiver and power the receiver OFF when I power TV OFF. So first thing is to react on the power state of the receiver (can’t find a bridge for my TVtherefore I use the receiver). Next to turn on the lamp BUT only is the sun is set.
Turning on the lamp is working but I can’t figure out how to handle the “but only if..” part using the Sun_Set_EndTime.
This is the code:
“status”: {
“status”: “IDLE”,
“statusDetail”: “NONE”
“triggers”: [
“id”: “1”,
“label”: “an item state changes”,
“description”: “This triggers the rule if an item state has changed.”,
“configuration”: {
“itemName”: “YamahaReceiverRXV675_Power”,
“state”: “OFF”,
“previousState”: “ON”
“type”: “core.ItemStateChangeTrigger”
“conditions”: [
“inputs”: {},
“id”: “3”,
“label”: “an item has a given state”,
“description”: “Compares the item state with the given value”,
“configuration”: {
“itemName”: “Solen_Set_EndTime”,
“state”: “END”
“type”: “core.ItemStateCondition”
“actions”: [
“inputs”: {},
“id”: “2”,
“label”: “send a command”,
“description”: “Sends a command to a specified item.”,
“configuration”: {
“itemName”: “LED_Reol_Power”,
“command”: “ON”
“type”: “core.ItemCommandAction”
“configuration”: {},
“configDescriptions”: ,
“uid”: “7325a2ad-917f-431d-b5ce-368501c921a5”,
“name”: “TV kig slut”,
“tags”: ,
“visibility”: “VISIBLE”,
“description”: “Når Yamaha slukkes tænder LED reol”
Rule 2:
This rule shall switch on two lamps when we reach Sun_CivilDusk_StartTime. Nothing happens. (Probably the same problem as in rule 1).
This is the code:
"id": "1",
"label": "a trigger channel fires",
"description": "React on events from a trigger channel of a thing.",
"configuration": {
"event": "START",
"channelUID": "astro:sun:local:civilDusk#event"
"type": "core.ChannelEventTrigger"
"conditions": [],
"actions": [
"inputs": {},
"id": "2",
"label": "send a command",
"description": "Sends a command to a specified item.",
"configuration": {
"itemName": "LED_Reol_Power",
"command": "ON"
"type": "core.ItemCommandAction"
"inputs": {},
"id": "3",
"configuration": {
"itemName": "SpotTrappe_Power",
"command": "ON"
"configuration": {},
"configDescriptions": [],
"uid": "d2ab6082-d70a-41e4-984d-5bf9a79cbaab",
"name": "Alrum aften",
"tags": [],
"visibility": "VISIBLE",
"description": "Tænder lys i alrum ved skumringstid"
What have I done wrong?
