Since upgrading to OH3 I have an issue with a rule which doesn’t get triggered anymore.
The rules should get triggered when a certain scene is activated by a switch on the KNX-bus.
This is the item:
Number Szenen "Szenen" <none> (gALL, gLOG)
The item is linked to a Number-control channel on the KNX binding (was a Number channel before, I changed it to Number-control to see whether this makes any difference) - DPT 17.001
Here is the rule:
rule "GoodN8"
Item Szenen changed to 5
logInfo("TEST", "GoodN8 Szene aktiviert.")
val String[] exceptions = newArrayList("Licht_Vorraum_Lampe")
var onLights = gLights_E1.members.filter(x | (x.state == ON || x.state > 0) && exceptions.contains( x.name) == false)
onLights.forEach [light|
logInfo("GoodN8", light.toString + " ist aus.")
sendCommand( light, OFF)
onLights = gLights_E2.members.filter(x | (x.state == ON || x.state > 0) && exceptions.contains( x.name) == false)
LSSchlafzimmer_Volume.sendCommand(18)
createTimer(ZonedDateTime.now.plusMinutes(10)) [|
Licht_SZ_dim.sendCommand( OFF)
createTimer(ZonedDateTime.now.plusMinutes(25)) [|
LSSchlafzimmer_Volume.sendCommand(15)
createTimer(ZonedDateTime.now.plusMinutes(30)) [|
LSSchlafzimmer_Volume.sendCommand(12)
createTimer(ZonedDateTime.now.plusMinutes(35)) [|
LSSchlafzimmer_Volume.sendCommand(10)
createTimer(ZonedDateTime.now.plusMinutes(38)) [|
LSSchlafzimmer_Volume.sendCommand(8)
createTimer(ZonedDateTime.now.plusMinutes(40)) [|
LSSchlafzimmer_Volume.sendCommand(6)
createTimer(ZonedDateTime.now.plusMinutes(45)) [|
LSSchlafzimmer_Volume.sendCommand(4)
createTimer(ZonedDateTime.now.plusMinutes(46)) [|
LSSchlafzimmer_Remote.sendCommand(PAUSE)
GoodN8_ON = true
Szenen.postUpdate("99")
When I activate the scene the item does get updated to 5, but the rule doesn’t get triggered.
What am I missing here?
