Hey everybody,
i’ve a simple solution to close the rollershutters by numbers, which is not working for all kind of rollershutters that have only actuators for up and down.
It is not perfect but i think enough for the most. The idea is to set the rollershutters by a given time. So you have to change the time for your rollershutters by looking how long it takes till the the rollershutter is closed.
The rule is needed because the current openhab alexa skill has no functions for all needed rollershutter operations.
The following functions did i make for my special rollershutter actuators which can only move DOWN or UP. You can change the functions for your needs.
My home automation system uses a KNX bus system.
The rule function to move the shutters up.
val org.eclipse.xtext.xbase.lib.Functions$Function3<SwitchItem, Long, Number, Boolean> moveUp = [
rollerShutterItem, time, receivedCommand |
rollerShutterItem.sendCommand(UP)
rollerShutterItem.sendCommand(receivedCommand)
createTimer(now.plusMilliseconfs(time), [| sendCommand(rollerShutterItem, STOP)]
true
The rule function to move the shutters down.
val org.eclipse.xtext.xbase.lib.Functions$Function3<SwitchItem, Long, Number, Boolean> moveDown = [
rollerShutterItem.sendCommand(DOWN)
true
The following method checks which value you have said to alexa. The values 10, 20, 30, 40 up to 100 are available to let the rollershutters going down for a specific time (10 for about 10%). The values are always relative. So when you want to close your rollershutters to 80% you must be sure that they are fully opened or in case that they are 20% you can close them for 60%.
To let the rollershutters going up you can use the values 5, 15, 25, 35 up to 95.
The value 0 stops the current process.
val org.eclipse.xtext.xbase.lib.Functions$Function5<SwitchItem, Number, Long, org.eclipse.xtext.xbase.lib.Functions$Function3<SwitchItem, Long, Number, Boolean>, org.eclipse.xtext.xbase.lib.Functions$Function3<SwitchItem, Long, Number, Boolean>, Boolean> rollershutterEchoSetFunction = [
rollerShutterItem, receivedCommand, maxCloseTime, moveUp, moveDown |
if(receivedCommand == 0) rollerShutterItem.sendCommand(STOP)
else {
// Calculate whether this is an UP or DOWN command
val up = if(receivedCommand % 10 == 0) false else true
// Calculate the time
val time = (maxCloseTime / 10) * Math::round((receivedCommand / 10).floatValue)
if(up) moveUp.apply(rollerShutterItem, time, receivedCommand)
else moveDown.apply(rollerShutterItem, time, receivedCommand)
true
The example rule that uses the functions above.
// Rollershutter rules for Amazon Echo FirstFloor.
rule "Rollershutter_ParlorBalcony"
Item FF_Rollershutter_ParlorBalcony_ECHO received command
var inputValue = receivedCommand as DecimalType
rollershutterEchoSetFunction.apply(FF_Rollershutter_ParlorBalcony, inputValue, 23000L, moveUp, moveDown)
23000L is the time which is needed to close the balcony rollershutter completely.
If you have any questions, improvements, ideas please let me know.
Cheers
