I try to make rule work.
I have Fibaro wall plug and wanna trigger power consumption,
What i doing wrong?
The “State” field is what the Item’s state should be to trigger the Rule. I’m going to guess the state of this Item is a number. A Number Item will never have a state of “POW Watts”. And since you have a condition to check if it’s over 100, you probably don’t want to put anything at all in the State field.
But you’ve given absolutely no details about what it is you are actually trying to do nor what the Items is so it’s hard to say.
Hi. i try to switch lights on if TV is on.
I use wall plug to measure power consumption of TV.
Now its working.
I deleted old rule and made same rule again.
