I am using openhab 2.4 on a RPi3+. I am having problems during startup, some rules are executed although the openhab doesn’t seem to be ready. Example:
2019-05-10 17:32:32.178 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'KNX IP interface online systemstart': The name 'VerbindungKNXInterface' cannot be resolved to an item or type; line 13, column 17, length 22
2019-05-10 17:32:46.854 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'System started Logik': The name 'logInfo' cannot be resolved to an item or type; line 30, column 5, length 46
Items and even builtin function names are unknown to the rule engine. There are no spelling errors and the rules are executed correctly after some minutes, if the trigger reocurrs. However some triggers like
Thing 'knx:ip:bridge' changed from UNKNOWN to ONLINE
don’t reoccur which poses some problems to me. Yes I could work with timers, but probably also the timer function will not be known yet.
Is there a solution to this startup order problem?
This is unfortunately a well-known and still not fully resolved issue, mostly there are issues with persistence, but I have seen the errors you are encountering myself; there are various work-arounds for now that you can use:
the simplest way is restarting OH2 a few times (w/o deleting the cache and tmp files), this can solve this issue, but may not always work
Hmm, I’m not sure if this is really the same problem. The problem is not that the state of the items are not yet known, but that the items and even system keywords like “loginfo” are not yet known. However I will read into and try the suggested solutions in the next days.
I didn’t find the option in openhabian-config yet, how is this called there?
It seems that I only can activate this (ot at least I don’t see an indication - just the fact, that the .rules are renamed to .x files)
How to deactivate this function?
