I am executing multiple commands via single rule (like a mood or scene activation) but there is a lot of delay in this execution from pressing a button on IOS app the execution of rule and commands inside happens after 3-4 seconds this makes the user feels that nothing happened by pressing button and tend to press it again. Any pointers to improve this ?
I run system on Pi3 and “top” shows me Java taking up close to 100% of cpu most of time.
rule “LR_AllOff_Fast”.. i have mix of Items from Hue to Zwave to lightwaverf in single rule as below -
Mmh. A RPi3 is way fast enough and OH should need far less CPU.
Check logging, in particular increase it for rules. <logger name="org.openhab.model.script.rules" level="DEBUG" />
Reinitializations use 100% CPU They’re taking place after you change items, rules or sitemaps.
While this is normally accomplished in less than seconds, if a rule fails to load or crashes during execution, this can become a repetitive process, resulting in permanent CPU load you’re seeing.
Thanks for the pointer .. however i am using OH2 and i cannot figure out where to put the logging statement for “rules” as there is no logbook.xml in OH2 .. can you suggest further.
